Help!! Stripped the head of the 10mm oil plug drain - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Aug 6th, 2008, 7:27 am   #1 (permalink)
Hi All
In a move of utter stupidity and tried to loosen the drain plug in the wrong direction. The result, a plug thats screwed in very tightly and a "stripped" head. Looking at the hex shape in the plug it's defintely a bit distored and the 10mm hex will not engage. If too much force is applied, it rotates within the plug's head.
Options? I have a 11mm allen wench on order and may see if that will fit in. What about an easy out? Any ideas? Thoughts?
'04 Ducati ST4s with ABS
Boston, MA
deanp is offline   Reply With Quote
Old Aug 6th, 2008, 8:38 am   #2 (permalink)
martys's Avatar
Images: 4
what about an SAE hex wrench that's slightly oversized from the 10mm? hammer it in, break the plug loose, and replace it with a new one.
2010 MTS 1200s
martys is offline   Reply With Quote
Old Aug 6th, 2008, 9:30 am   #3 (permalink)
what's a Fly N Fink?
flynfink's Avatar
Images: 10
Since the plug is basically a pan head bolt with a hex head, I used a cold chisel and hammer the last time the hex head stripped out on my son's 900ss (PO had already rounded it off). Then got a new bolt. Shouldn't be that tight.
Jeff F.
2004 ST4S - Red, of course
2004 M1000 - Red also
2007 Porsche Cayman S - Black is bad
2007 Honda Ridgeline- Daily Driver and hauler
flynfink@yahoo.com
www.carolinariders.com
www.usdesmo.com
flynfink is offline   Reply With Quote
Old Aug 6th, 2008, 9:47 am   #4 (permalink)
cagivaduc's Avatar
Images: 6
Dip the hex head in oil, then in sand. I think I saw that in some manual. Worked for me on a former bike.
'95 900SP
'93 900SS
former bikes:
'86 Cagiva Alazzurra 650
2 other other '93 Supersports
'96 MZ Skorpion
'74 Indian Enduro
lots of 70's hondas
cagivaduc is offline   Reply With Quote
Old Aug 6th, 2008, 10:16 am   #5 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
Whoa. That is a great idea.
Committing that to memory. Thanks.
tony b
2001 ST4
tonered is offline   Reply With Quote
Old Aug 6th, 2008, 2:54 pm   #6 (permalink)
Corse1's Avatar
Images: 2
Thank you Desmo Times.....Lt's manual is where the sand idea is written
Corse1
03 ST4s ABS (2006 -)
07 Tuono 1000R (2011 -)
03 Aprilia Tuono RSV 1000 Racing (2011-2011 Crashed)
06 1050 Speed triple (2009-2011)
Corse1 is offline   Reply With Quote
Old Aug 6th, 2008, 3:07 pm   #7 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
I'm a couple thousand miles from the 24k mile service. I have a whole list of DT goodies including LT's manual. Though, I am going to start asking around locally for anyone that would like to share a shim kit.
Have a good one.
tony b
2001 ST4
Old Aug 7th, 2008, 12:04 am   #8 (permalink)
PeteST4's Avatar
G'day... Grinders paste works well... Also is good for stubborn phillips head screws, a little dab hey presto! good grip..
Cheers PC...
Thurgoona near Albury NSW Oz.
Yellow 02 ST4
DP Pipes/ Ultimap chip K&N..Sargent seat 'n' other stuff..............
PeteST4 is offline   Reply With Quote
Old Aug 7th, 2008, 9:46 am   #9 (permalink)
thanks guys!!!
Boston, MA
Old Aug 7th, 2008, 10:43 am   #10 (permalink)
lifes_an_ocean's Avatar
I believe I've seen replacement oil drain plugs which have a nut for use with a standard socket/spanner, rather than the recessed allen key. I think these were also drilled for safety wire. Anyone remember where they could be purchased?
Black 2005 ST3
lifes_an_ocean is offline   Reply With Quote
Is This Another Oil Drain Plug?? smeres Superbikes 1 Jun 19th, 2008 10:09 pm
2005 999R oil drain plug torque? fastbydrmike Superbikes 3 Mar 14th, 2008 8:13 am
stripped hex hole on drain plug Kgizzle1 Ducati Motorcycle Chat 28 Sep 20th, 2007 1:24 pm
Over-tightened oil drain plug...crank thread stripped..now what? hypnotic Superbikes 17 Sep 3rd, 2007 9:05 pm
