Headlight High Beam Bulb Popping - Ducati.ms - The Ultimate Ducati Forum
Old Jan 17th, 2007, 1:19 am   #1 (permalink)
The bulb for the blue light on my 2000 ST4 instrument panel keeps popping. I have replaced the bulb 3 times since early December. The headlight itself works fine on both dim and high settings, but the bulb pops within 2 or 3 uses of engaging a high beam setting.
I have checked the obvious connections but have found nothing that looks or feels wrong.
Any suggestions ?
David Macfarlane (aka Willy)
Cape Town, South Africa
2004 ST3 (the wife's)
2000 ST4 (mine)
Willy_Mac is offline   Reply With Quote
Old Jan 20th, 2007, 8:50 am   #2 (permalink)
Stick's Avatar
Vibrations? Something loose causing the gauge cluster to rattle?
Or
Maybe you're driving at too low RPM to cause the condition above. In the taller gears, I try to make sure I'm ABOVE 4000 RPM.
Stick
Other brands (past):
Headlight bulb fasterdammit Monster 2 Nov 6th, 2006 3:12 pm
headlight aim rider851 Superbikes 2 Oct 13th, 2006 1:33 am
Double headlight mod 916....... DukeDesmo Hall of Wisdom 2 Aug 19th, 2006 5:42 pm
2000 748S - what's the headlight bulb? H3? H1? aa240sx Superbikes 2 Aug 7th, 2006 2:43 pm
No high beam?? jaymags Superbikes 8 May 13th, 2006 10:22 am
