Originally Posted by ST4s4SF
Raj, Thanks for your reply. I am not sure what two-sided bolt you are speaking of. Can you give me any further details? Is it on the back of the cluster, so i'd need to take it all apart again to check it? (I'm just trying to avoid taking the whole thing apart several times) Or are you speaking of one of the anchors for the console's trim?
The bolts I am talking about are the ones that go into the instrument cluster on one end. Then you use a nut on the other end to secure it to the plastic dash panel. They are threaded on both ends with a rubber spacer between. They are the part right next to number 13 in this schematic:
Schematic (Bike Bandit)
Since the part is two screws embeded in the rubber spacer, one bolt can break loose but still appear to be attached. I had one do this. So it looked bolted tight from the back of the plastic panel, but was loose at the instrument cluster.
On all the later model STs I have seen the instrument cluster stands a little off the plastic instrument panel. It shouldnt be touching the panel at all.
Okay, I read your post again (which I should have done better the first time). If the noise is coming from the plastic panel that goes up against the headstock (part 6 in the schematic), a piece of foam stuck to underside should do the trick.
Raj
