Jul 4th, 2012, 10:00 pm
Batt died while riding, stuck on road. Help!
Ooooook. So, I have the bike in my sig, and let it sit for three weeks while I was away, and came back to a dead battery. No problem, threw it on the charger and topped it off.
Went out for a test ride and not even 5 miles down the road, the dash lights go dim, and eventually the batt light comes on and the bike sputters and shuts down. I managed to get to a safe spot, but now here I am with no juice.
Dash lights come on dim. Only enough power to kick the bike over once then all lights die.
What could have caused my battery to do that? Bad regulator?
Thanks in advance.
Silver 1998 ST2
Mods: FIM Chip, Big bore kit w/Hi Comp Pistons, Lightened flywheel, cut airbox w/K&N, Corbin seat, Heli Bar Risers, Ducati Designs Headlight
Jul 4th, 2012, 11:00 pm
98 ST2? Yep!, Bad regulator is your most likely culprit. Check the output at the battery. If you're not getting around 14v by 2-3k rpm, your regulator is fried.
Check the wiring from the stator to the regulator as well, mine was burnt.
I replaced my regulator with a MOSFET unit from a kawasaki. Here's the thread that inspired me.
finding new voltage regulator to fit ST-2
'98 ST2
'84 Kawasaki Gpz Turbo
Jul 5th, 2012, 12:20 am
Start by Cleaning the terminals first.
Rod
2005 ST-3 RED
Jul 5th, 2012, 9:42 am
Terminals are def clean. Have the powerlet starter wire upgarde kit installed. Just installed a new sprag gear and the thing has been firing up instantly till this.
Where should i check to see if the regulator is bad...right at the batt?
I was able to jump the bike to get it home last night...but it ran like $#!T! Lights went dim and flickered with the RPMS, and bike sputtered like hell. If i gave it some more throttle it would take off then bog down...and sputter...etc. JUST loped it into my driveway, thankfully.
What goes bad on the stator? I was just in there changing the sprag and everything looked normal.
Silver 1998 ST2
Jul 5th, 2012, 12:11 pm
First start by charging the battery over night so you know its at full capasity.
then find the molex conector from the sator to the regulator yours is a 98 so i belive it will have only 2 yellow wires not the 3 of the later units but i could be wrong.
Anyway pull the conector apart and Using a volt meter set for AC volts measure the voltage betwwen the two yellow wires from the stator you should have 40 volts AC at idle and 60-100vac with the blip of the throttle. If so the regulator is likely at fault.
See the post above.
99 Ducati ST4. Fast by Ferracci Carbon cans and Ultimap ECU
"Smok'in the competition NOT Tobacco"
"Transplant organs, Don't bury them!"
Jul 5th, 2012, 1:19 pm
It's gonna be a good year tater!
Ducati had a recal on the 98 stator and voltage regulator. They also changed a spacer between the sprag and the flywheel that had a modified groove in it to sling oil to the top of the stator where they were over heating.
AMA Member
1998 Silver ST2$
Jul 5th, 2012, 1:36 pm
See the post above.
That the big wire thats clipped under the steering bearing? The one that comes out of the crankcase on the stator side?
Silver 1998 ST2
Jul 5th, 2012, 2:06 pm
Yes that should be it. Mines a 99 st4 on it the conector is white nylon and has 3 yellow wires your should be just 2 yellows.
Jul 5th, 2012, 6:43 pm
Recently I found my main fuse, the big 40amp Maxi-Fuse (next to battery) had best I can tell, vibrated apart. Check that too.
t_bare
1 Ducati = Ducatista
2 Ducatis = Mechanic
2002 Ducati 998 Faster Banana!!!
2000 Ducati ST4
2000 KTM 300 EXC
1998 KX250
