Bike No Worky - Ducati.ms - The Ultimate Ducati Forum
post #1 of 13 (permalink) Old Apr 16th, 2012, 3:07 pm Thread Starter
Bike No Worky
I'm looking for some input on non-running ST4s. I just got back from a ride where the bike just quit on me. I attempted to start it once I got pulled over and it turns over well but just won't start. While cranking it seems to turn over faster when I open the throttle. The dash appears to work fine; the clock is operational, fuel gauge looks right, temp gauge is reading properly.
It seems like a fuel pump problem but I'm very worried that its the ECU. At this point I haven't been able to diagnose anything as its still at a dealer that picked it up for me.
Any thoughts?
thanks, Dan
'12 Multistrata-S touring; '02 Aprilia Futura - sold
'04 ST4s - sold; '04 VFR - sold
jobslob is offline
post #2 of 13 (permalink) Old Apr 16th, 2012, 3:25 pm
Mr Leakered
tonered's Avatar
Images: 25
Fuel line popped or split. Seeing a lot of swirling action with the lid open and the key turned on will usually confirm it.
Curious, do you recently fill up? It seems to happen most often with a full tank.
Have a good one.
tony b
2001 ST4 - Thumper
2013 Ural GearUp - Taildragger
tonered is offline
post #3 of 13 (permalink) Old Apr 16th, 2012, 3:30 pm
stryder's Avatar
If not a burst or spit off fuel line in the tank, it may be that the crank position sensor is swarfed up, and needs to be wiped off. Good luck.
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
stryder is offline
post #4 of 13 (permalink) Old Apr 16th, 2012, 3:33 pm
Have a good one.
+1 on that... if it were the ECU I would expect to see coughing and stumbling on start up with either an extremely lean, or rich running condition...
Listen for the pump priming when you turn the key to see if you hear anything at all... if you don't, try swapping the relays (fan to fuel pump) to see if that gets it the pump working....
'08 848, Red (Termi's.. not much else needed)
'01 ST4, Blue (Arrow Pipes, Ohlins Rear Shock, Alum. Swingarm, DD Headlight, CRG Levers, CycleCat Risers)
'02 Monster 750S i.e., Senna (Remus Pipes, Rizoma Triples & Clip-ons / Belt Covers/ Mirrors/ Sprocket Cover)
ducati_750 is offline
post #5 of 13 (permalink) Old Apr 16th, 2012, 3:42 pm
Stick's Avatar
Could be the pump. We trouble-shot a stranger's ST4s at the Dragon a couple years back. Gent filled up, bike didn't start. No F.Pump noise...traced voltages all the way to under the tank connector. Finally slapped the tank while he turned the key on--pump came on, and he was a very happy camper!!
Stick -~~~- Need an adrenaline rush? Shove a DUC between your legs.
Present DUCs: 2003 ST4S, 2001 ST2, 1996 900 SS/CR, 1996 900 SS/SP
Stick is offline
post #6 of 13 (permalink) Old Apr 16th, 2012, 3:46 pm
Mr Leakered
tonered's Avatar
Images: 25
Ducatidiag will also run a long fuel pump test that you can peek around while it is running.
Have a good one.
tony b
2001 ST4 - Thumper
tonered is offline
post #7 of 13 (permalink) Old Apr 16th, 2012, 3:54 pm Thread Starter
Thanks for the quick replys. I did just top off the tank 2-3 miles before it quit. I did stop at a bike shop for about 10 minutes between the fill up and having it quit. I was also in the tank this winter to replace the fuel filter so its certainly conceivable something came off in there.
I'll be sure to check all of that when I get it back home.
jobslob is offline
post #8 of 13 (permalink) Old Apr 16th, 2012, 4:00 pm
Mr Leakered
tonered's Avatar
Images: 25
I’ve had to learn to really crank down on the hose clamps. More than I feel okay about.
Have a good one.
tony b
2001 ST4 - Thumper
tonered is offline
post #9 of 13 (permalink) Old Apr 16th, 2012, 4:20 pm
replace the front left relay....or swap it with the one below and see if it fires.
Those who dance are considered insane by those who can't hear the music.
2002 Ducati ST4S
volleykinginnc is offline
post #10 of 13 (permalink) Old Apr 16th, 2012, 10:38 pm
This +1
Or try the fuel pump relay under the seat.
2002 ST4s, 2004 BMW R 1100 S
KarlFitt is offline
Human Verification
WTB: Ducati 848 or 1098 track bike/road bike das134 Bikes 0 Aug 7th, 2011 4:07 pm
Wich bike to turn into a race bike Filantroop Superbikes 27 Jan 6th, 2010 9:27 am
buying first bike, ducati or japanese starter bike? audi15psi Ducati Motorcycle Chat 33 Jul 17th, 2008 10:30 pm
fuel pump no worky Bevel-Heaven Superbikes 8 Mar 18th, 2007 2:28 am
