Removing rear fender - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.comGraves Motorsports
Patriot Powersports
Old Jan 29th, 2012, 4:00 pm   #1 (permalink)
bandited's Avatar
Finally got some heat in my garage here to do a few up-grades. Notice that i couldn't remove the rear finder off. Do you need to drop the rear wheel all first???
Ed
2003 ST4S
2006 Suzuki Bandit 1200
bandited is offline   Reply With Quote
Old Jan 29th, 2012, 4:20 pm   #2 (permalink)
MarkST's Avatar
Ed, do you mean the hugger or the mudguard that the license plate bolts to ?
You don't need to remove the wheel for either, but they can both be a bit of a bastard due to seized nuts/bolts etc.
Mark.
MarkST is offline   Reply With Quote
Old Jan 29th, 2012, 7:05 pm   #3 (permalink)
bandited's Avatar
Mark I mean the hugger. The tip of it (chain guard) hits the underside of the seat. Kind of scared of breaking it.....Have no problem removing the bolts.
2003 ST4S
Old Jan 30th, 2012, 12:25 am   #4 (permalink)
MarkST's Avatar
That's not right, it shouldn't do that.
I'd say your spring is way too soft for your weight, and/or you need to raise the ride height.
You are very lucky Ed.
So you got it off ok then ?
Old Jan 30th, 2012, 4:43 am   #5 (permalink)
bandited's Avatar
Mark, I should have said it hits the oil breather tank not the seat.... At least I think that is what it is. Haven't got it off yet!!!
Ed
2003 ST4S
Old Jan 30th, 2012, 9:41 am   #6 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
Mine does scrap a bit when removing it. Wrap a cloth around the bit making contact and flex it gently out. Of course, my plastic hugger is more flexible than the very nice carbon one that came with the s.
Have a good one.
tony b
2001 ST4
tonered is offline   Reply With Quote
Old Jan 30th, 2012, 12:11 pm   #7 (permalink)
MarkST's Avatar
Actually Ed, thinking abut it a bit, it probably would be a lot easier without the wheel in there.
748 / removing rear drive pins from hub Patman Superbikes 2 Jul 14th, 2011 12:10 am
Removing Rear Sprocket Chcek Johnny Sport Touring 5 Mar 7th, 2009 10:21 am
Removing Rear Seat Cowl tomuchwrk Superbikes 4 Jun 8th, 2008 6:17 am
removing rear head graham Supersport 5 Oct 5th, 2007 7:23 pm
Removing Rear Wheel of St4s SouthEastNCST4S Sport Touring 8 Mar 3rd, 2007 5:06 pm
