Coolant dripping... - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Jan 23rd, 2012, 7:26 am   #1 (permalink)
jobst3's Avatar
Coolant dripping...
After a recent 250mi ride (nice break in the weather) I have a small puddle under the bike. Coolant is leaking from the waterpump cover inlet tube and it is nicely corroded too. (this bike isn't that old?!?)
Is there a simple repair for this, or does it require replacing the cover?
While the billet covers are cool and all, I have used up most of the bike budget and it's only January!!!!
Jon OB
2007 ST3s
2000 1100xx
2001 VFR (R.I.P. - damn deer)
jobst3 is offline   Reply With Quote
Old Jan 23rd, 2012, 7:53 am   #2 (permalink)
RUNnDUC's Avatar
Images: 13
A photo of the failed part and a more complete description of the failure would be a help to the rest of us in assisting you in the offering suggestions for the repair.
Not seeing it my first thought is checking with Gotham for a used replacement cover and a new gasket. You may only need a gasket. Their prices are reasonable and the times that I have traded with them they were very professional. As far as replacement will cost, it is as about a cost effective as replacement can be.
Proud owner of a 02' ST4s (BB) grey, the stealth color.
________________________________
My old ride is swinging past Pluto, other rides, some looking out, some looking in, some repairing of others and sadly the R/D on two broken and two retired. . .
”Without deviation from the norm, progress is not possible.”
– Frank Zappa
RUNnDUC is online now   Reply With Quote
Old Jan 23rd, 2012, 9:08 am   #3 (permalink)
Moderator
stryder's Avatar
Coolant leaks from ST bikes are common and most often fixed by....tightening the hose clamps.
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
Old Jan 23rd, 2012, 9:12 am   #4 (permalink)
Stick's Avatar
Coolant leaks on our STs are very common. I believe it's due to the OEM hoses that are not very good quality. I think they weep out of the fiber inner layer. One cure is silicone hoses (kit). I've tightened, retightened, replaced hose clamps with wider ones.
A few years back, I alerted my local dealer to a brand new ST3 on his showroom floor with a coolant drip onto the carpeting. It's usually the top hose on the radiator. And you can feel it thru the left air conveyer.
I tend to live with mine, and the weeps seem to subside in warmer weather. It's COLD in my garage, and I noticed a small drip this past week on the concrete. Same ol' same ol'.
edit: Frank beat me to it. I agree. Start by firmly snugging all of the clamps.
Stick
Other brands (past):
Old Jan 23rd, 2012, 9:31 am   #5 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
Also, the inlet tube is threaded into the water pump cover. Some folks have a very bad time getting a good seal there when they go to a billet cover. So, don't rule out that the inlet pipe is leaking from the threads. You shouldn't have to replace any parts.
When I replaced my coolant hoses with silicone ones, I found coolant weeping from the fabric layer like Stick noted.
Have a good one.
tony b
2001 ST4
tonered is offline   Reply With Quote
Old Jan 23rd, 2012, 10:14 am   #6 (permalink)
Stick's Avatar
Tony, about how much $$'s for those aftermarket hoses, and where would you recommend buying them?
Not sure I need the extra bling, since the fairing hides all that cute stuff! (and anti-freeze is relatively CHEAP!!)
Stick
Old Jan 23rd, 2012, 11:13 am   #7 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
I got mine from desmotimes. I think I paid $160 for the kit (hoses and clamps). LT has a waiting list now. The cost is a bit more now.
They have three layer of fabric / four layers of silicon. Attached is a pic. You can see some of the construction on the lower rad hose. I couldn't attach full size.
These are definitely lifetime hoses judging that the originals made it about 10yrs.
Have a good one.
tony b
2001 ST4
Old Jan 23rd, 2012, 11:27 am   #8 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
BTW, the red of these hoses goes well with my blue ST. I would think that they would look just as good on a yellow ST. But, it is a lighter shade of red that might look a bit off on a red ST, depending on how you feel about thinks like that.
This was definitely a functional purchase for me.
Have a good one.
tony b
2001 ST4
Old Jan 23rd, 2012, 11:35 am   #9 (permalink)
jobst3's Avatar
Thanks for the input guys!!
I will drain the coolant and see what I can see. (pix too)
The silicone hoses look like the long term fix, but I've only seen them for the ST4, not the ST3's -- in the pix they seem to be different?
It needs a coolant change anyway so...
Jon OB
2007 ST3s
2000 1100xx
Old Jan 23rd, 2012, 1:15 pm   #10 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
Sorry for the OT. The ST4/ST4s use different lines.
Good luck.
Have a good one.
tony b
2001 ST4
Coolant dripping out but still to hot billington92 Superbikes 8 Jun 30th, 2009 12:36 am
Gas dripping from overflow hose? Motard-Menace Sport Touring 23 Jun 16th, 2009 9:45 am
2004 749s - -a little dripping problem. wantaduc Superbikes 1 Mar 20th, 2009 11:39 am
Water Dripping? AXE HyperMotard 8 Jan 28th, 2008 11:30 pm
996 fuel tank dripping from fittings cmlf1 Superbikes 3 Aug 18th, 2007 11:44 pm
