Mirror stalk cracking repair - Ducati.ms - The Ultimate Ducati Forum
Old Jan 17th, 2012, 2:52 pm   #1 (permalink)
Does anyone have a grasp on why our mirror stalks crack at the base on the back side? has anyone done a successful fix? My right side is missing a big chunk, the left one is cracking in the same area but hasn't lost any plastic yet. Not only do I not want to pay the $$$ for new ones, I don't want to just watch it happen again.
1998 ST2
erikrichard is offline   Reply With Quote
Old Jan 17th, 2012, 2:56 pm   #2 (permalink)
Starting to have the same problem on mine also.But don't have and answer..lol
superpimp is offline   Reply With Quote
Old Jan 17th, 2012, 5:56 pm   #3 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
Jerks in parking lots bumping into them? Do you find them sitting on the lip of the rubber grommet often? I do sometimes, but I know who has hit mine, the Wife and Kids.
Mine also see a lot of hot and cold cycles sitting outside during the work day, but we don't get very high temps here. Basically a few days in the lower 90F per year.
That said, no cracking of the stalk as of yet.
Have a good one.
tony b
2001 ST4
tonered is offline   Reply With Quote
Old Jan 21st, 2012, 9:37 am   #4 (permalink)
Who knows. Maybe those Italians overtightened the bolts holding the mirrors down while they were sucking cappuccino on the assembly line. I have the unfortunate experience of having disassembled my mirror for some work and I still can't re-latch the spring that holds the mirror unit to the base & stalk. !@#$.
chitownson is offline   Reply With Quote
Old Jan 21st, 2012, 11:07 am   #5 (permalink)
Life is too short to worry !
Gearbox's Avatar
Wink
Obtain some strong cord , make a loop long enough to attach to the spring and feed through the stalk , pull hard until you are able to hook the spring inplace then use ablade to cut the cord and remove.
Gearbox is offline   Reply With Quote
Old Jan 21st, 2012, 7:47 pm   #6 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
I believe the OP was talking about the plastic stalks, not the metal base.
Have a good one.
tony b
2001 ST4
749 exhaust manifold cracking. bmxer4liffe Superbikes 3 Nov 28th, 2011 9:10 pm
749 exhaust header cracking bmxer4liffe Superbikes 6 Aug 29th, 2011 2:04 pm
Cracking Paint Trenman Superbikes 1 Jan 2nd, 2010 6:28 pm
999 instrument cluster cracking. Patrick_P Superbikes 1 Jul 13th, 2008 3:15 am
Short Stalk LED Indicators Kramer Ducati Motorcycle Chat 5 Jul 27th, 2006 11:18 am
