Replacing the cush bushings - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jan 14th, 2012, 10:42 am   #1 (permalink)
motersikelist's Avatar
Upon inspecting the rear wheel at 50K miles everything looks good except for some slight play (1 mm) between the cush bushings and rear sprocket flange. Nothing shows excessive wear but is 1 mm within acceptable limits?
If the bushings need to be replaced, is there a recommended removal method?
Thanks, Andy
Have fun-be safe, Andy
'07 Ducati ST3s ABS (DP kit)
motersikelist is offline   Reply With Quote
Old Jan 14th, 2012, 11:51 am   #2 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
I didn't see any tolerances mentioned in the service manual?
Here is a thread on replacement.
Cush Drive Bushing Replacement?
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Jan 14th, 2012, 1:09 pm   #3 (permalink)
I didn't see anything in the shop manual either. Thanks for the link.
Where to find fork bushings? Phober HyperMotard 1 Oct 15th, 2011 4:04 pm
Replacing Cush Drives GaClique Superbikes 4 Jun 3rd, 2011 9:29 pm
WTB: titanium cush bushings toobs1234 Parts and Accessories 0 May 5th, 2010 1:40 pm
rubber tank bushings? jetboy Vintage 2 Dec 7th, 2008 4:02 am
Rear Wheel Bushings krantz Supersport 3 Jun 7th, 2006 8:27 am
