I have a tonered - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jan 12th, 2012, 6:40 pm   #1 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
I have a tonered
OK, 34 k on the bike and I have a small tonered on the horizontal cylinder! Nothing to major.
I was thinking that I would pull the jugs, lap the heads to the cylinders, lap the valves, remove any carbon from the pistons, valves and heads, new rings and clips. Just a basic refresh on the top end. I ordered a new top end gasket set.
I may want to paint some of the motor components on the lower end.
Anything I should look for? Any suggestions? What type of paint should I use?
Thanks in advance...
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Jan 12th, 2012, 7:02 pm   #2 (permalink)
MarkST's Avatar
Household interior emulsion should be fine.
I'd use vinyl silk though, It'll wipe down easier.
MarkST is offline   Reply With Quote
Old Jan 12th, 2012, 7:05 pm   #3 (permalink)
Bill A's Avatar
no suggestions from me. hhahahahhaaa
I have no idea what that means!
Mercy!
Bill A is offline   Reply With Quote
Old Jan 12th, 2012, 8:48 pm   #4 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
LO-freakin'-L. How'd you get a tonered on you horiz cyl?? I ony do verts! =P
I was just ready to post about my sticky piston. =)
One of the caliper pistons was hung up (hung, haha). So, I squeezed one too many times. I'm glad I did. They were all a bit nasty (nasty, haha).
Well, just about done and waiting for the Wife to return with some lube. . . I mean fluid...brake fluid. LOL.
Tooooo many IPAs. No breaking the pads tonight. =P
Have a good one.
tony b
2001 ST4
tonered is offline   Reply With Quote
Old Jan 12th, 2012, 8:49 pm   #5 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
Max,
I need a new Avi. Post one up! =P
Have a good one.
tony b
2001 ST4
Old Jan 12th, 2012, 9:44 pm   #6 (permalink)
mbevans's Avatar
After a simple lap & clean, a little coppercoat gasket sealer does wonders to get rid of most Tonered problems....
I've sealed 890cc barrels on an older 748s of mine, amazing stuff.....
2002 Ducati ST4S (Yellow, the faster color)
2008 Aprilia RXV550 (My current monster for the dirt)
2006 Ducati 999s (Sold)
2001 Ducati 996 SPS (Crashed)
2001 Ducati 748-890 (Sold)
1997 Ducati 748 (Sold)
1993 Ducati 888SPO (Crashed)
Too much Jap crap to mention!
mbevans is offline   Reply With Quote
Old Jan 12th, 2012, 11:37 pm   #7 (permalink)
is a tonered cylinder what happens when you get your photocopier and motorcycle repair chemicals mixed up?
1998 ST2
Rev. Dr. Moses P. Lester is offline   Reply With Quote
Old Jan 13th, 2012, 2:53 am   #8 (permalink)
va duc's Avatar
Images: 12
Have a good one.
Actually the leak is on the Vertical cylinder, I misspoke.
Interesting... I will give it a shot. Are you referring to applying the sealant around the o rings themselves?
AMA Member
1998 Silver ST2$
Old Jan 13th, 2012, 3:16 am   #9 (permalink)
va duc's Avatar
Images: 12
I had to google that.
I'm thinking textured myself.
AMA Member
1998 Silver ST2$
Old Jan 13th, 2012, 4:58 am   #10 (permalink)
MarkST's Avatar
I wondered whether it would translate well 'across the pond'
Yeah that'd work. Only on the bottom end though, I don't think it would look right on the rest of the motor.
Tonered MarkST Sport Touring 16 May 17th, 2011 10:05 pm
