fuel line - Ducati.ms - The Ultimate Ducati Forum
Old Jan 5th, 2012, 2:33 am   #1 (permalink)
ddmv's Avatar
Talking fuel line
Hi all.
New to this forum, as I just brought (4 months ago) an 03' ST4s.
Great bike for my purpose as a commute & touring.
Anyway went to to take it out for a spin. And when it startred it up I noticed a strong smell of fuel.
Turn off the bike, look underneath and notice fuel leaking.
So back on center stand. Removed the fuel tank (with was full) and noticed one of the lines was disconnected from a "Y" junction.
Re-connected and went for a short ride to see how it went.
All seemed fine, and no smell of fuel.
So to cut a long story short, Should there be any cable/ tie down to the "Y" junction connection. Or was i just unlucky.
Any information would be great.
Cheers
ddmv is offline   Reply With Quote
Old Jan 5th, 2012, 2:39 am   #2 (permalink)
cb4265's Avatar
Originally Posted by ddmv View Post
Hi all.
Cheers
Hi & welcome, your problem could be as simple as a slightly overfilled tank, this can happen quite easily, not a big deal if you jump on & ride but looks messy if it sits there on the side stand.
Craig
I'll try to be nicer, if you try to be smarter.
R.I.P. #58
WLF ViVa La Figa
2002 ST2 RED
STAINTUNE Stainless Steel Pipes
MICHELIN PILOT ROAD 3's
http://www.youtube.com/watch?v=wDMlso1fUYY
cb4265 is online now   Reply With Quote
Old Jan 5th, 2012, 4:10 am   #3 (permalink)
ddmv's Avatar
Craig
Hi Craig.
Thanks for your reply. Here is a photo (a bit small) of the fuel line that was disconnected.
To me (being a novice at these thing ) it looked liked that line was directly from the tank.
So i don't quite understand (again being a novice) how it became loose.
Thanks
dino
Old Jan 5th, 2012, 4:27 am   #4 (permalink)
cb4265's Avatar
Hi Craig.
Thanks
dino
Sorry mate, not what I thought, photo doesn't really help, you will work it out by eliminating problems. Fuel filters are the biggest drama you will have, unlike the yanks with their shit ethanol fuel that plagues them.
What other symptoms or causes do you suspect?
Craig
R.I.P. #58
WLF ViVa La Figa
2002 ST2 RED
Old Jan 5th, 2012, 4:34 am   #5 (permalink)
Life is too short to worry !
Gearbox's Avatar
These are just over-flow pipes and if you have a really full tank and leave the bike on its side-stand then fuel will exit under the bike but if they become detached then the fuel will leak onto the engine and evaporate.
They do not usually pop off but perhaps the rubber is a little tired and loose in your case.
Gearbox is offline   Reply With Quote
Old Jan 5th, 2012, 4:53 am   #6 (permalink)
ddmv's Avatar
Thanks for your input "gearbox". That might be the case of just tired & loose hose.Will have to look into one at the next service.
I allways keep the bike on the centerstand when at home. To be on the safe side.
Thanks again for your help.
Old Jan 5th, 2012, 4:58 am   #7 (permalink)
ddmv's Avatar
No, thanks again for your help in this Graig. Yeah not the best photo.
But it could just be a worn out/loose hose connection as "gearbox" said.
Well i keep an eye on it.
Stayed tune.
Old Jan 5th, 2012, 5:06 am   #8 (permalink)
cb4265's Avatar
Stayed tune.
Mate, for fuck sake can spell you my name right, it's the least you can do ?
Craig
R.I.P. #58
WLF ViVa La Figa
2002 ST2 RED
Old Jan 5th, 2012, 5:28 am   #9 (permalink)
ddmv's Avatar
Craig
F$@# me. Sorry Craig.
Now THAT is very very embarrassing for me. I didn't even realise i was doing it. That's what i get for being a stay at home dad and not dealing with adults. It's all baby talk all day for me.
Sorry again.
Old Jan 5th, 2012, 12:10 pm   #10 (permalink)
Still needs a life.
Bill_Anderson's Avatar
Images: 19
Another common source of fuel leaks is failure to properly shut the fuel cap. After shutting the cap and removing the key, press down on the cap with your thumb and listen for the reassuring click.
As some said earlier, do not put an ST on its side stand after topping off the tank or you will get fuel leaking out the overfill hose down the side of the engine. Guess how I know.
Bill_Anderson is online now   Reply With Quote
748-Fuel line routing does the out line run to the front or rear cylinder st_pinetree Superbikes 5 Aug 24th, 2011 7:55 am
Fuel Line came off!!!! 88sporty Sport Classic 3 Nov 13th, 2007 8:41 am
The Dreaded Fuel Line/Fuel Pump Separation Revisited BlackDuck Sport Classic 3 Sep 21st, 2007 5:51 am
Fuel Line, Fuel Filter, and Fuel Overflow Line Questions? Glockem Supersport 1 May 14th, 2007 9:17 pm
Fuel line QD, is there another way? archer Superbikes 4 Nov 10th, 2006 4:49 pm
