Fan & Steering Upgrade - Ducati.ms - The Ultimate Ducati Forum
Old Jan 4th, 2012, 8:51 pm   #1 (permalink)
bandited's Avatar
Thinking about purchasing the fan upgrade from Desmo Times. Do you think that it makes a big difference with this fan???
Also one other question. I purchased 1" risers recently off of Ebay. I have been looking at the Cycle Cat DBR5 Bar Mounting. If I decided to purchase this can I use the risers with the cycle cat bar?? Or am I wasting my money. Should I try the risers first then go from there??
Ed
2003 ST4S
2006 Suzuki Bandit 1200
bandited is offline   Reply With Quote
Old Jan 5th, 2012, 6:11 am   #2 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
The fan is a great upgrade whether you install the override switch or not. I can't recommend it enough, it moves more air and keeps the bike cooler. Some folks have had to trim the blades a bit to get a proper fit, well worth the effort.
If you have the money the cycle cat system is bling heaven. Try the risers if you want, they do help some folks enough without needing the cycle cats. I installed the risers, then the heli bar system as the cycle cats were not available for some time.
Good luck no mater which way you decide.
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Jan 5th, 2012, 7:03 pm   #3 (permalink)
mlukason's Avatar
The previous owner of my ST3 installed the Desmo Times fan and switch. I've never had a problem with cooling...lots of air movement with his blade. The over-ride switch is a good idea...when I sit at a light or am in traffic I flip the switch and within seconds the temp starts to drop.
Great investment.
Mike
2006 ST3
Bikes of the past:
1989 BMW K100RS ABS
1983 BMW R65LS (never should have let it go!)
1976 Honda CB750F
1976 Honda CB360T (the start of it all)
mlukason is offline   Reply With Quote
Old Jan 5th, 2012, 9:52 pm   #4 (permalink)
C-simian's Avatar
Vinnie R. did a great write-up on a ST4s fan over ride switch installation a while back: Fan Relay bypass question
I followed suit, since I didn't really like LT's set-up. The switch I used was a bit more robust than Vinnie's, I believe, but also obtained from Radio Shack. I installed it on the right hand side, and set a heat-shrink boot over the switch, after filling it with dialectric grease, so as to be reasonably water resistant. Very happy with the result.
I've attached three jpegs, first with the switch I installed vs. the one Vinnie used (according to the part number he gave). Second the full switch system prepared for installation, complete with fuse, and finally the switch installed on my right hand bracket for the brake reservoir. After that, I put the heat-shrink boot over it, with the grease, but somehow don't have a picture of the final product. This spring, I'll redo my electrics and put in one of the Centech AP-2 fuse panels, so that my air horn, heated gear, GPS and other stuff can be handled more elegantly.
Oh, and it works well with the CycleCat risers I installed, just some minor fitment modifications with the reservoir. Both mods highly recommended.
Ron
Fan & Steering Upgrade-switch-comparison.jpg   Fan & Steering Upgrade-ready-installation.jpg   Fan & Steering Upgrade-switch-installed.jpg
2005 999s Hephaestus
2003 ST4s ABS Senna Petrarch
C-simian is offline   Reply With Quote
Old Jan 6th, 2012, 6:10 am   #5 (permalink)
bandited's Avatar
Thank you all for the information. I just order the the fan yesterday and hope to be able to work on the bike over the winter here.
Ed
2003 ST4S
Old Jan 6th, 2012, 7:12 pm   #6 (permalink)
mbevans's Avatar
Can't go wrong with his kit. I as well bought both the fan and the switch kit, flawless, and runs considerably cooler when it kicks on....
Though tie the fan main power to a switched 12 volt power!
Ed
2002 Ducati ST4S (Yellow, the faster color)
2008 Aprilia RXV550 (My current monster for the dirt)
2006 Ducati 999s (Sold)
2001 Ducati 996 SPS (Crashed)
2001 Ducati 748-890 (Sold)
1997 Ducati 748 (Sold)
1993 Ducati 888SPO (Crashed)
Too much Jap crap to mention!
mbevans is offline   Reply With Quote
Replace/upgrade forks v steering damper tonys1100s Sport Classic 27 Jul 31st, 2010 9:07 pm
LED upgrade squarecat Sport Classic 4 Sep 15th, 2008 12:05 am
Model differences in steering / steering damper AAL Sport Classic 9 Sep 9th, 2007 1:21 pm
GT ECU Upgrade egrafx2006 Sport Classic 0 Dec 25th, 2006 11:10 am
To Upgrade Mts 620 To 750 Upgrade? jasper91 Ducati Motorcycle Chat 7 Dec 14th, 2006 5:37 pm
