To replace the battery do you have to remove the middle right panel? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 3rd, 2012, 3:27 pm   #1 (permalink)
fcnorton's Avatar
I have to replace my battery and wondered whether I could just remove the lower right panel to get access or if the whole right side needed to come off?
Thanks for your help!
FC Norton
AMA Member
2007 ST3 - Red
"I have not a particle of confidence in a man who has no redeeming vices."
Mark Twain
fcnorton is offline   Reply With Quote
Old Jan 3rd, 2012, 3:38 pm   #2 (permalink)
DuckMan's Avatar
I do. It may be a pain but it's better than breaking some very expensive plastic.
Mike
DuckMan is online now   Reply With Quote
Old Jan 3rd, 2012, 8:58 pm   #3 (permalink)
fcnorton's Avatar
Fyi
The answer is NO...just removing/loosing the lower right panel does not give sufficient access to replace the battery.
As you can see from my signature, I have the 2007 ST3. I loosened the lower and then removed the middle right panel after loosing up all the top dash/windshield bolts. Removal was really easy...HOWEVER.
It took some "manipulating" to get the middle right panel back on...things in my favor...it was WARM, low to mid 70's AND I took my time and didn't force anything. I wish I could tell you the "trick" but I worked with it until it just fit.
Bottom line is that it is DOABLE...even for a mechanical "spaz" like me.
Good luck!
PS: Thanks for all the hints in the Sticky section on battery replacement. I made DAMN sure that it was facing the right direction before hooking everything up in the order outlined. No problems...back to my daily commute!
FC Norton
AMA Member
2007 ST3 - Red
Mark Twain
Old Jan 4th, 2012, 3:23 am   #4 (permalink)
was able to do it on my 2004 ST4 by just removing the lower fairing a loosening up some of the top screws and the big on on the middle fairing.
1965 Suzuki Hilly Billy (stolen)
1968 Kawasaki A1SS
1970 Kawasaki A7
1978 Suzuki GS400e (sold)
1980 Suzuki GSX550e (sold)
1982 Honda CB400 (sold)
1983 Yamaha XT125 and DT 125 (traded in)
1988 Yamaha DT200 (traded for leathers)
1988 Gilera Saturno 500
1993 Ducati 750SS
2004 ST4s ABS (yeller)
Mad Dog is offline   Reply With Quote
Old Jan 4th, 2012, 6:00 am   #5 (permalink)
Ken
Ken's Avatar
Caution: Refer to Sticky above on properly connecting the battery. Its very easy to hook up the battery backwards in this battery box (positive to negative, negative to positive), especially when using the Yuasa battery.
I just finished a valve adjustment on my ST3 and did just that. It fried my ST3s ECU. Luckily, the good folks at Ducati Omaha are re-flashing a used ECU for about $400. A new one would have cost well over $1000. A very costly mistake.
Ken Krumm
2004 Ducati ST3 43K - original owner
2004 BMW R1150GS 82k- original owner
1996 BMW R1100RT 137k - original owner
1996 BMW K1100LT 150k - original owner
2003 KTM 450EXC 6k
Iron Butt Association Member
Ken is offline   Reply With Quote
Old Jan 4th, 2012, 8:37 am   #6 (permalink)
Stick's Avatar
I've owned ST# 's for about 10 years now. If/when I need to get into the battery area, I've ALWAYS removed the entire right side skin (starting at the dashboard, mirrors, front fairing, then right side. Never in my 10 years have I even separated the lower from the mid. I can't see any reason to (xcept for damage, maybe?).
FWIW, I actually R+R'd the huge wet-cell batt. from my ST2 one time, without removing any fairing pieces. Just to 2 belly bolts, the big side bolt, and flexed the fairing out, proped w/ ductape roll. Oh, I cheated a bit ahead of time and had access to the + terminal (modified the right air-conveyer). But the rest was done "by feel".
Stick
Other brands (past):
How to open key to replace battery... Mr Sunshine Multistrada 9 Nov 6th, 2010 10:16 pm
newbie wants to remove st2 seat panel desmoheadnj Sport Touring 3 Jun 21st, 2010 10:36 am
Lock cylinder remove-and-replace in top case? mwkingsandiego Sport Touring 3 Jul 29th, 2009 4:17 pm
New Exhaust: Should I remove Remus Sticker or replace it with...? ducatiti Supersport 31 Apr 23rd, 2007 8:13 pm
Remove and Replace Shock on Older SBK Buckelew Hall of Wisdom 0 Aug 20th, 2006 2:02 am
