Bar-end weights... - Ducati.ms - The Ultimate Ducati Forum
Old Jan 2nd, 2012, 11:31 am   #1 (permalink)
Bar-end weights...
Happy New Year all,
I have a slight vibration in my bars on my ST3...nothing bad, but there. I run stock bars attached to Heli risers.
I've heard of folks using Throttlemeister to help take the vibration out, leveraging the added weight of these bar-ends...
What do people suggest? Does Throttlemeister make a difference? Any other brands you would recommend that might be less expensive (I really don't care for cruise control...) ?
Cheers,
Bugs
Bugsy
  • 2006 ST3
  • 2007 Daytona 675
  • 2009 Bonneville
  • 2007 R1200GS
jazzgangsta is offline   Reply With Quote
Old Jan 2nd, 2012, 1:19 pm   #2 (permalink)
Ascalon's Avatar
I had a bit of experience with this myself on the 4s.
I found that someone had put two washers of relatively small diameter on the end of RH bar to ensure clearance between the throttle tube and the bar end weight.
I replaced this with two larger diameter stainless washers of 1mm thickness each and that greatly improved things.
On the LHS, I tried the same thing but it made it worse, then I tried three with no effect. I then tried just one and that seemed to tune it out.
So with one 1mm washer ont eh left and two ont he right, a nagging high frequency vibration at 120kph was successfully damped out for the princely sum of nowt.
Result!
A
2002 ST4s | Nullius in verba | 1991 ZXR750R
Ascalon is offline   Reply With Quote
Bar End weights ianhear Sport Classic 19 Aug 17th, 2011 5:25 am
DP Bar End Weights ranette Parts and Accessories 3 May 3rd, 2011 7:38 pm
Wheel Weights il Capo Sport Classic 6 Jan 11th, 2011 2:27 pm
Fun FYI> 916/748/998 weights Bruce_Allison Superbikes 10 Jul 15th, 2009 11:22 pm
Bar End Weights? wayon Sport Classic 11 Apr 4th, 2009 3:10 pm
