Dec 27th, 2011, 12:47 pm
ST4s speedo
The Speedo on my ST4s just quit.
I had had it apart to replace the LCD display.
But it worked for a few after the bike was all back together, and for 1.4 miles after filling the bike up. Then it just quit.
Anybody have this issue?
Is it something simple maybe, like the cable or the sender at the front wheel?
Or do I need to replace the speedo like I just had to replace the LCD on this thing?
TIA
Dec 28th, 2011, 10:32 am
Life is too short to worry !
What year is your bike - The earlier years had cable drive off the front in which case it could have become disengaged at the top (assuming you have not touched the wheel etc)
The later models had electric pick-up off the back wheel and that would then suggest a bad connection when reinstalling the read-out panel.
BTW Always a good idea to add your model and year to your profile to avoid being constantly asked when raising an issue.
Dec 28th, 2011, 1:05 pm
Still needs a life.
OP: Ditto what Gearbox said about posting the year and model of your ST in your public profile or signature line.
Dec 28th, 2011, 3:07 pm
I'm 100% with what Bill and Gearbox said about posting the year and model of your ST in your public profile or signature line.
Dec 28th, 2011, 3:19 pm
No, I did not originally post my year,
It is a 2002
But I did ask about the cable and sender at the front wheel.
Yes it is mechanical.
No, not as simple as comming undone at the top, first thing I checked because I just had the cluster apart to replace the LCD part..
Cables and senders have issues?
Or am I screwed?
TIA.
Dec 28th, 2011, 3:51 pm
It is a 2002
Would you be kind enough to put it in your sig via the quick links drop down menu at the top right of the page under where it says your screen name please.
Dec 29th, 2011, 3:52 am
It is a 2002
Or am I screwed?
TIA.
It is rare for the speedo to have problems so it may be worth removing and refitting the drive at the dial end if it was working fine before you worked on it as it may not be seated correctly.
By pure coincidence the inner cable could be damaged but doubt that as they dont appear to fail very often , especially at your low milage.
Dec 29th, 2011, 10:10 am
Mr Leakered
Actually they do fail. I had to replace the drive and cable a while back. The lower end can be checked fairly easily.
Have a good one.
tony b
2001 ST4
Dec 29th, 2011, 10:45 am
Do I have to post a new reply for my changes to show up?
I will check the inner cable first. That is the easiest.
I think it is engaged at top, I did re check that again.
I'll have to do some diagnostics..
2002 ST4s
Dec 29th, 2011, 6:29 pm
If the speed-o worked, and then did not (without taking the front wheel off) then the cable could be toast. Easy to check.
2002 Ducati ST4S (Yellow, the faster color)
2008 Aprilia RXV550 (My current monster for the dirt)
2006 Ducati 999s (Sold)
2001 Ducati 996 SPS (Crashed)
2001 Ducati 748-890 (Sold)
1997 Ducati 748 (Sold)
1993 Ducati 888SPO (Crashed)
Too much Jap crap to mention!
