Dec 26th, 2011, 9:20 am
Fuel Pump Relay
This pass summer my fuel pump relay under the seat went on me. It got so hot that the holder melted and the female connection on the harness has melted some what too. I was able to plug in a new relay but I like to replace the female end but looking at it doesn't look that easy. Anyone have any suggestions as what I should do with it?
Also what would have cause this relay to go like that. Is there a underline problem here that I don't know about??? Anyone else have this problem???
Ed
2003 ST4S
2006 Suzuki Bandit 1200
Dec 26th, 2011, 9:47 am
Over the summer I had to replace the relay and fuel pump on my s2r1k with a little under 3k miles. I was told that this wasn't a common part to go bad but was a one off.
'06 S2R 1000
Dec 26th, 2011, 11:58 am
Bandited, I don't understand.
On your 03 ST4s, the fuel pump relay is not under the seat. It is to the left of the headlight under the cowling piece.
... well ... at least mine is
Do you by chance have the ABS version ? There are some unused connections under my seat for that since it is not attached. Could this be what you're looking at ?
2003 ST4s
some other bikes too
.. and some other bikes but I sold them
Dec 27th, 2011, 4:35 am
I have a 2003 ST4s ABS. Under the seat is the fuel pump relay and the fan relay. Behind the upper fairing on the left below the fuse box is the main relay, the headlight main beam relay and the flasher unit.
I don't know what sort of ST4s you've got
2003 ST4s ABS
1994 907ie
Scotland
Dec 27th, 2011, 8:49 am
I don't have the ABS but I am sure its under the seat. One of my biggest concerns now is how reliable is my bike for taking out on long trips. I am not a mechanic and if there is any serious problems then I have a real problem!!!!!
2003 ST4S
Dec 27th, 2011, 11:14 am
relay location
My fuel pump relayand my fan relay along with a slightly larger relay, are on the outside of the fuse box.
I'll take a pic later today and post it.
What kind of ST4s do you have ???
2003 ST4s
Dec 27th, 2011, 12:22 pm
as always, it is a possibility I may understand this incorrectly;
the first two pics are relays located near my fusebox
This third pic is of my relays under my seat
after looking at the wiring diagrams, I realize I may be wrong, it shows several brown wires going to the fuel pump relay and one of the relays under the seat has several browns,
.... then what are the relays next to my fuse box ?
all four of these fuses are the same size, type
* added after further investigation
yes, the fuel pump and fan relays are under my seat, it appears the other relays near the fuse box are the main + lights relays (all 4 of these relays are are the same) nestled next to the flashing relay.
I learned somthing about my bike from this thread, good job
2003 ST4s
Reason: confusion
Dec 27th, 2011, 12:27 pm
.. and Bandited, check my gallery for pics of the brake line extender I got for the Dr Desmo risers.
(earlier thread we discussed about)
a melted relay under the seat ? wtf
never herd of this but I'd say it's serious.
I'm thinking it must have come from the electrical circut itself, I can't see ambient heat melting it and it's no where near the exhaust.
.. perhaps the vertical exhaust header is leaking or needs tightened ?
2003 ST4s
Reason: more stuff to say
Dec 27th, 2011, 1:56 pm
...after looking at the wiring diagrams, I realize I may be wrong, it shows several brown wires going to the fuel pump relay and one of the relays under the seat has several browns,
As I said in post #4 above.
2003 ST4s ABS
1994 907ie
Scotland
Dec 27th, 2011, 2:38 pm
send me a box of your dogs doo-doo and I'll rub it on my nose, ok ?
2003 ST4s
