Dec 26th, 2011, 6:44 am
This got me thinking. FWIW - the older ST2's don't have a bar end insert. The bar is cast and turned, and the bar end is drilled and tapped for 8mm coarse thread. This may be of no help at all for a later ST4s but after a run downstairs to check, I thought I'd write down the result.
'98 ST2, '75 Norton Mk III
Dec 26th, 2011, 6:54 am
Why not just get some heated grips ?
Actually, getting both might be good.
Dec 26th, 2011, 8:02 am
There was a thread about handguards -
Hand guards
I thought about doing this - but I also don't want to lose the ability to mount a Throttlemeister for the longer rides - can't see how to do both. I'll probably go with heated grips sometime before next autumn. Another confusing topic - there seem to be a lot of choices, each with good and bad points.
Dec 26th, 2011, 8:17 am
Mine were cheap and they get hot. That's 2 good points
Dec 26th, 2011, 9:12 am
I had heated grips on the K1200LT but found they weren't that effective; the elements heat the palms of your hands. After searching, I found a set of Widder gloves; they have the heating elements on the top of the gloves (where the wind is) and I prefer the gloves over grip heat.
Just my $0.02.
2006 ST3, Termi and ECU
Always, ride safe!
Avatar credit: RD Key
Dec 26th, 2011, 11:31 am
Just my $0.02.
,,,,,I have to agree also,the palm stays warm but it's the back of the hands and fingers that take the beating.Having both grip & glove heated pieces are perfect.
2007/ducati-ST3-S-ABS 2002-Honda 250
Dec 26th, 2011, 6:34 pm
Originally Posted by jssport
Mark, what grips did you go with ?
I can't remember to be honest, but I should be able to check it out for you. I think they were Oxford but I'll let you know.
Dec 30th, 2011, 5:09 am
Thread size
Thread size in my '99 is 8mm. I have hand guards on mine. Be prepared to adjust your steering stops a bunch to keep the guards from hitting the body work at steering lock.
If I had to do it again, I would go with heated grips and gloves. Only advantage with guards is ability to use regular gloves a little longer. Still need heated gloves when it gets really cold.
