the plastic cap on the end of the fandango mounts - Ducati.ms - The Ultimate Ducati Forum
Old Dec 15th, 2011, 11:44 pm   #1 (permalink)
sk57's Avatar
You know the little plastic cap that covers the aft end of the nonfango pannier mounts. I need one of those. The Ducati parts manual doesn't list it as a part. Anybody know where to get one? So far I've resisted the black electrical tape fix.
sk57 is offline   Reply With Quote
Old Dec 15th, 2011, 11:57 pm   #2 (permalink)
jet057's Avatar
Walk in on a local shop and ask.That part should be easily located.
2007/ducati-ST3-S-ABS 2002-Honda 250
jet057 is offline   Reply With Quote
Old Dec 16th, 2011, 3:53 am   #3 (permalink)
Life is too short to worry !
Gearbox's Avatar
I doubt a shop will hold such a part but you could try emailing your US Importer or Distributor for Non-Fango who might be able to help.
(Didn't they go bust though ? If so would be Givi you need as the rails are pretty much the same for both)
Gearbox is offline   Reply With Quote
Old Dec 22nd, 2011, 5:36 pm   #4 (permalink)
cb4265's Avatar
Got a photo of the cap?
What does it do? What problem are you having?
Craig
I'll try to be nicer, if you try to be smarter.
R.I.P. #58
WLF ViVa La Figa
2002 ST2 RED
STAINTUNE Stainless Steel Pipes
MICHELIN PILOT ROAD 3's
http://www.youtube.com/watch?v=wDMlso1fUYY
cb4265 is online now   Reply With Quote
Old Apr 25th, 2012, 2:13 pm   #5 (permalink)
rspcharger's Avatar
Images: 10
Nonfango is actually still around. I found a customer service email thru Nonfango.com. I contacted them and this winter for about $5 thru paypal I was able to get the rubber bumpers for my pannier frames. They also threw in the tube end caps, but were the wrong size. Get on Google to search for tube end caps, its a common item for desks, chairs & whatnot. I got free samples from one company to replace my missing one. Sorry I don't have any details on name or contacts.
~Regan
Issaquah, WA
________
2000 ST4
2000 Suzuki GSF1200s Bandit [Sold]
2005 Moto Guzzi Breva 750ie
2011 Triumph Sprint GT
rspcharger is offline   Reply With Quote
Old May 20th, 2012, 9:35 pm   #6 (permalink)
rspcharger's Avatar
Images: 10
Solution
Originally Posted by rspcharger View Post
.........Get on Google to search for tube end caps, its a common item for desks, chairs & whatnot. I got free samples from one company to replace my missing one. Sorry I don't have any details on name or contacts.
I found who I got it from: Component Force - Plastic Caps, Plastic Plugs, Tube Inserts, Rubber Feet, Castors, Hand Grips & Plastic Sleeves, Nylon Parts, Rubber Caps & Plugs - Component Force - USA - search their "oval insert" section based on the size of the tube. I narrowed it down to 2 & they sent me a free sample of each (I only needed 1).
~Regan
Issaquah, WA
________
2000 ST4
What's involved going from low mounts to high mounts? bobross Supersport 6 May 11th, 2008 11:49 am
Need details about ECU mounts fester Supersport 0 Jan 21st, 2008 5:32 am
Top case mounts ColinF Sport Touring 7 Nov 8th, 2007 6:55 pm
gps mounts; tricky_dickey Sport Touring 5 Apr 26th, 2007 7:37 pm
GPS Mounts. z24b Sport Touring 2 Apr 22nd, 2007 11:25 am
