Need help with starter sprag removal / installation - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
SportbikeTrackGear
Old Dec 11th, 2011, 11:28 am   #1 (permalink)
Lray's Avatar
I've gotten the flywheel off my bike and discovered the spring to the starter sprag had exploded. I went ahead and ordered a new sprag, which I have now. I can't figure out how to get the old one completly out and the new one in. The bottom part of the sprag is pinched in the flyweel. How does this come out? I took the screws out from the back of the flywheel thinking that would open it up, but it doesn't, it's like it's pressed together or something. Does anyone know how to fix this? Everything I've looked at shows the sprag just coming right out, which is not the case with this bike, it is an 02 ST4S. Any insight would be greatly apreciated. I'm ready to get her back together. Also, the repair manual says that I need to replace the alternator nut. When I ordered the sprag the guys at the Ducati shop told me that they don't replace them. Anyone reuse these nuts succesfully? I'm trying to put a picture up, but it's not working.
thanks,
Lray is offline   Reply With Quote
Old Dec 11th, 2011, 4:51 pm   #2 (permalink)
MarkST's Avatar
You have 3 days left to freely download a workshop manual from the last post on this link - • View topic - 2001 ST4s Workshop Manual if you don't already have one.
Meanwhile, if you put your bike model and year in your sig it will make things a lot easier all around in the long run.
MarkST is offline   Reply With Quote
Old Dec 11th, 2011, 5:28 pm   #3 (permalink)
Lray's Avatar
Right on, I've already got the shop manual. It doesn't help a whole lot. I've also got Snyders book, it shows the sprag just coming right out.
2002 ST4S
Old Dec 11th, 2011, 5:33 pm   #4 (permalink)
MarkST's Avatar
Cheers Lray.
I can't really help any further than that then on this issue, but rest assured somebody will post soon with the answer to your problem.
Old Dec 12th, 2011, 4:55 am   #5 (permalink)
Put 4 of the bolts back in but not all the way and spaced out so they are like 3,6,9 and 12 O'Clock positions, and lightly tap them with a hammer!! make sure the flange ring comes out straight!! It was not that tight on mine! I had exactly the same thing happen on mine so check the condition of the flange ring and also the starter gear. If they are both work you can end up distryoing the new sprag! I ended up buying a used flywheel assembly off ebay which only cost me £40 and chaned the whole lot!
John
Ducati ST4S 2002 "Bitch"
Ducati ST2 2002 " Scarlet"
Yamaha DT175MX 1983 "Yasmin"
mw0dbb is offline   Reply With Quote
Old Dec 12th, 2011, 8:25 am   #6 (permalink)
Lray's Avatar
Thanks
2002 ST4S
Starter sprag repair st2lemans Ducati Motorcycle Chat 26 Aug 3rd, 2010 4:26 am
M900 1995 starter sprag kiwiz Monster 5 Sep 11th, 2009 5:01 pm
Starter clutch/sprag for an S4 dickster Monster 0 Aug 14th, 2008 1:59 pm
part number for starter sprag? jamesmorgan Supersport 0 Jul 25th, 2007 10:16 am
2 Questions about starter motor/sprag clutch issue...will starter motor spin in rever Desmo Soundtrack Superbikes 7 Sep 19th, 2006 8:00 am
