Battery for '05 STS - Ducati.ms - The Ultimate Ducati Forum
Old Dec 1st, 2011, 4:22 pm   #1 (permalink)
Battery for '05 STS
I thought I might order one of the Motelectric cable upgrades so checked the PO's maintenance records and mine because I don't recall ever getting a new battery. Seems this is the original battery. 6 years? Is this thing doomed to fail any second? Anyway, what are your recs for a Brand replacement? Thanks.
Ducati ST4S abs 2005 - Red!
Ducatak is offline   Reply With Quote
Old Dec 1st, 2011, 4:50 pm   #2 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
You are skating on thin ice.
Go with a Yusa, my 2 cents.
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Dec 1st, 2011, 5:08 pm   #3 (permalink)
kaysystems's Avatar
My battery was taxed to start the bike after 6 years. After 7 it wouldn't turn over if the temperature was below about 40 degrees.
A new Shorai cured the problem (and saves over 5 pounds in weight)
David
Ducati rider since '74
1966 250 Mark3
2004 ST3
kaysystems is online now   Reply With Quote
Old Dec 1st, 2011, 5:30 pm   #4 (permalink)
ducat's Avatar
I have had good luck with these batteries in several bikes and order from this company in Oregon. Quick free shipping to my door.http://www.batterystuff.com/powerspo.../sYT12B-4.html
1 SBK, 1 ST, 1 Monster.
ducat is offline   Reply With Quote
Old Dec 1st, 2011, 5:37 pm   #5 (permalink)
$67 on that Scorpion. Much better than the $116 dealer quote an a replacement Yuasa. Where do you guys get your batteries usually? Online? CycleGear?
Old Dec 1st, 2011, 6:55 pm   #6 (permalink)
va duc's Avatar
Images: 12
Buy yuasa!
Yuasa Battery YT12B-BS YUASA BATTERY YUAM6212B
AMA Member
1998 Silver ST2$
Old Dec 2nd, 2011, 11:38 am   #7 (permalink)
ducat's Avatar
Honestly, I've had better luck with the scorpions than the yuasa. Especially with my dirt bikes. Oh, and the little woman's Monster that sits far to often.
Old Dec 2nd, 2011, 8:22 pm   #8 (permalink)
Official Sponsor
motolectric's Avatar
The strongest battery you can buy is an Odyssey. They weigh a little more than a Yuasa or any other AGM (I'm pretty sure they have more lead plates). But they are by far the strongest and if used with one of their chargers will probably give the longest service life and lowest overall cost of ownership.
The Shorai seem to be excellent. I have one in my bike now. They also need a smart charger of some type for best performance.
In the Bay Area we are probably okay with their low temp shortcomings but I'll find out through this winter.
And you are right to be thinking of a new battery, once they get to the edge, they can tank pretty fast. A 6 year service life is really excellent for any battery.
When I lived in SF I used to eat 2 wet cell batteries a year (1 per bike).
HTH
Michael Heth
mheth@motolectric.com
Motolectric.com | Innovative Electrical Upgrades For Motorcycles Since 2002 |
Also available through Motolectric | Remus - Melvin - Odyssey - Shorai - Magnecor - Scotts Dampers - Traxxion Fork Upgrades - TFX Custom Shocks |
motolectric is offline   Reply With Quote
Old Dec 14th, 2011, 8:41 am   #9 (permalink)
blue44's Avatar
looks like batterystuff sells the Yuasa battery also, $7 more.
2004 Ducati Batteries | Batteries for Ducati Motorcycles
that lithium-iron battery is interesting at a little over 2 lbs., but kind of spendy...
question - do you remove the nose fairing when taking off the side fairing ? the manual didn't say so, but I had a heck of a time getting the upper side fairing back under the nose fairing. ( had to jump-start sunday ) found the bracket at the back of the nose fairing was bent by the po's tipover, so I've got to go back and r&r that...
one of these years I'll buy a used bike that doesn't need a battery first thing...
Donn
Donn
'04 st4s senna / heli bars / silmoto carbon exhaust
'98 f650 (sue's)
previously - '01 r1150gs / '94 k75s / '71 r75/5 / '80 cx500 / '70 h1 / '72 cl350
blue44 is offline   Reply With Quote
Old Dec 14th, 2011, 9:34 am   #10 (permalink)
ninja's Avatar
Either Yuasa or Westco
I've had very good experience with both.
The shortest distance between two points is a straight line but how much fun would that be!
'04 ST4S ABS
'03 HD Road Glide
'06 HD VRSCR
ninja is offline   Reply With Quote
DIY: 696/796/1100 battery cable and battery upgrade romancommander Monster 16 Jan 2nd, 2012 11:37 pm
Battery's so dead, Battery Tender will not charge it... Tag Sport Classic 11 May 29th, 2011 3:31 pm
Bad battery or something else? TAftonomos Ducati Motorcycle Chat 2 May 7th, 2011 5:18 pm
Dead Battery 2004 ST4s "is it a special or regular off of the shelf battery?" 2UpDuc Sport Touring 26 May 10th, 2008 2:10 pm
Battery box for smaller battery John Superbikes 8 Dec 2nd, 2007 9:29 pm
