The clutch micro switch on the 2003 ST4s is a piece of crap. When mine gave up I fitted a microswitch the same as the brake one, the master cylinder casting is already drilled for it. I had to make a small pushrod with a flange on it so that it won't fall out when the lever is pulled to actuate the switch.
2003 ST4s ABS
1994 907ie
Scotland
