Nov 27th, 2011, 10:19 pm
Alternative front calipers
So, are there any no modification alternatives to the 2 pad calipers for post '04 ST'S?
'04 ST3
'07 GT1000
'08 Multistrada /s
'11 Harley Street Glide
Nov 28th, 2011, 5:56 am
Yes get a set of 749/999 or mille brembo P4 four pad calipers.
I've got them on my ST2 with wave disks and they work a treat with one finger braking.
Tim
ST2 1998 custom
Nov 28th, 2011, 6:02 am
...and much less prone to warping and or causing judder I would wager
John
2002 ST4S
Reality is an illusion caused by a lack of alcohol
Nov 28th, 2011, 6:12 am
You could go with the 4 pad calipers that were available on the Superbikes (998S and 749/999) before they all went to radial mounts. You'll need to replace the brake lines as the angle on the banjo fittings is not the same. Supposedly they are a pretty significant upgrade, but I don’t know from experience, just what those who have done it have said.
What are you after? I would say you could also go nuts and drop lots of cash on monoblock race spec units, but to what end?
If you're unhappy with the braking performance, it may be a lot less expensive to buy a different set of pads... If you want eye ball popping stopping power (read harsh in my book) I have a set of EBC HH pads you can have. I have gone to Ferrodo platinum and love them.
Dan.
A man said to the universe:
"Sir I exist!"
A sense of obligation."
Stephen Crane
Nov 28th, 2011, 12:54 pm
Thanks for the offer. I guess what I'm looking for is relief from brake chatter. The brakes stop well enough for me, but the chatter is driving me nuts!
(Insert head slap here!) I should have remembered that I put the 4p/4p Brembos' on my GT when I changed the forks to ST4s's. I suppose once the weather changes, I could try 'em on the ST.
'04 ST3
'07 GT1000
'08 Multistrada /s
Nov 28th, 2011, 1:01 pm
Life is too short to worry !
I doubt the calipers cause the chatter you speak of , many have had this problem at some time and it appears to down to various causes , Pad Material build-up , stiff bobbins , badly serviced calipers etc.
If you want better braking thats a different issue of course
Reason: Spelling , as usual !
Nov 28th, 2011, 5:27 pm
Originally Posted by moto
How do you remove the old buttons? I'm highly considering the "buttons" and wasnt sure how to remove the old ones.
2005 ST3
Past Bikes, 1985 RZ-350, 1988 FZR400, 1994 CBR-F2(RACE), 1998 TL-S, 2001 R6, 2002 CBR 954, 1999 R6(RACE), 2004 CBR 1000RR, 2005 R1, 2008 CBR 1000RR
Nov 28th, 2011, 6:48 pm
Ducati.MS sponsor
We drilled the old ones out. It was very easy with a drill press.
Our website has an install video when you go to that product:
CORSE DYNAMICS Full Floating Rotor Button
Nov 28th, 2011, 11:21 pm
I used that very tool with just ok results. Got rid of some of the chatter, but it still raises it's ugly little head. I'm going to try the buttons, staring to clutch at straws here.
'04 ST3
'07 GT1000
'08 Multistrada /s
