How is anyone mounting/wiring GPS? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 26th, 2011, 1:51 pm   #1 (permalink)
Where do I put this? I have seen a mount peg going into a handlebar end but don't know where to find one. HELP Please?
Nashduc
in the garage...when not riding
2005 ST3
1964 Honda Super Hawk (restore)
Nashduc is offline   Reply With Quote
Old Nov 26th, 2011, 2:05 pm   #2 (permalink)
Still needs a life.
Bill_Anderson's Avatar
Images: 19
I have used the Ducati Designs GPS mount for several years.
Ducati Designs, LLC - Mini Mount ST
Bill_Anderson is online now   Reply With Quote
Old Nov 26th, 2011, 2:22 pm   #3 (permalink)
mlukason's Avatar
Nashduc,
I use a RAM mount ball that sold by Desmotimes:
Desmo Times Product 89- Steering Stem Nut
The GPS is cradled in a RAM mount:
RAM GPS Cradles - Garmin Nuvi - Garmin Mount - GPS Mount - TomTom Mount
The site has lots of options for you to mount just about anything. For the wiring...I've run a "cigarette lighter" (from Powerlet: SAE To Cigarette Socket Cable (3") - Powerlet Products) socket from the battery. This is tucked up, along with the cable from the Garmin GPS, under the dash just behind the headlight housing.
Good Luck!
Mike
2006 ST3
Bikes of the past:
1989 BMW K100RS ABS
1983 BMW R65LS (never should have let it go!)
1976 Honda CB750F
1976 Honda CB360T (the start of it all)
mlukason is offline   Reply With Quote
Old Nov 26th, 2011, 4:23 pm   #4 (permalink)
Ducati Designs
pgeller's Avatar
Images: 27
There is unused switched (by the key) power near the instruments. The connector is tied up below the instrument cluster. It is protected by a 5A fuse in the fuse box.
pg
DD
pgeller is online now   Reply With Quote
Old Nov 27th, 2011, 2:24 am   #5 (permalink)
Maverick's Avatar
Hi Nashduc,
I've also got the steering stem ball mount from Desmotimes, and at first tried the cradle that was delivered with my Garmin Zumo 660. That worked fine most of the time, except for a certain rpm range around 4000rpm where the vibrations caused the GPS to lose external power momentarily, causing annoying messages on the screen. I used a rubber-mounted Touratech GPS Mount to solve that problem. I'm very happy with it. Yes.. quality equipment doesn't come cheap. I've seen that there's a new version (2.0) of that mount available too.
To power the GPS, I use a key-on 12V signal that comes directly from the wiring harness.
Cheers,
Mark
Ducati ST3s ABS '07
Now in a theater near you!
Maverick is offline   Reply With Quote
Old Nov 27th, 2011, 5:55 pm   #6 (permalink)
mlukason's Avatar
I choose to keep the power on the GPS all the time. It seems that during rest stops, we all congregate around my bike and play with the GPS for extended periods of time.
Mike
2006 ST3
Bikes of the past:
1989 BMW K100RS ABS
1976 Honda CB750F
Old Nov 27th, 2011, 9:53 pm   #7 (permalink)
whitelightning99's Avatar
I've used an additional circuit panel on most of my bikes. It allows the most flexibility in choosing how to power whatever widget I choose to use. Sometimes I want power on all the time, other times only when the key is on. It also reduces the number of connections on the battery, and simplifies wiring. For the GPS, I first power my tankbag, and tap off that for my Desmo Times Ram Ball mounted GPS. I love the tankbag power!
'04 ST3
'07 GT1000
'08 Multistrada /s
'11 Harley Street Glide
whitelightning99 is online now   Reply With Quote
Old Apr 12th, 2012, 1:28 am   #8 (permalink)
jssport's Avatar
Images: 40
pg
DD
Paul,
what years / model(s) have this ?
which fuse in the fusebox is it ?
2003 ST4s
some other bikes too
.. and some other bikes but I sold them
jssport is online now   Reply With Quote
Old Apr 12th, 2012, 1:38 pm   #9 (permalink)
620rossco's Avatar
Mounting is an issue with a steering damper.
No wiring I just power it with 2 small solar panels with batteries in the map pocket of the tank bag.
They give me about 10hrs each, one is always recharging.
Rossco
ST4s 03 'SL900 S5 #6 '84 S2.
620rossco is offline   Reply With Quote
Old Apr 12th, 2012, 7:47 pm   #10 (permalink)
mlukason's Avatar
That sounds cool! Do you have a pic?
One downfall of my system (hot at all times) was realized last week...I forgot to unplug after a ride then a stretch of cold and rain came in...dead battery.
Thinking about changing over to the switched power source.
Mike
2006 ST3
Bikes of the past:
1989 BMW K100RS ABS
1976 Honda CB750F
Sat Nav mounting duke900ssd Superbikes 7 Mar 26th, 2011 11:24 am
Don't start before mounting! iproto HyperMotard 43 Jul 31st, 2008 7:27 pm
Mounting it all up... TAftonomos Superbikes 0 Jan 8th, 2008 10:47 pm
998 ECU mounting...... Angus Superbikes 9 Mar 19th, 2007 7:16 am
GPS mounting Duc4Doc Sport Touring 3 Mar 9th, 2006 5:46 pm
