ABS Pump Failure - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 23rd, 2011, 9:41 pm   #1 (permalink)
Nomore76's Avatar
Images: 4
ABS Pump Failure
Why does this stuff never happen when I'm just around the corner from home?
Last June, while half way through a four day ride and 500 miles from home, my ABS light came on. I stopped, turned the bike off/on, and the problem went away. Problem solved, or so I thought.
Three months later, this time only 300 miles from home, the light started acting up again. Only this time it wouldn't ever go out. Plus, I had a noise that sounded like gravel in a coffee can coming from somewhere inside the fairing. However, the brakes seemed to work fine and I was able to maker it home.
Finally got the bike into the shop (Wilson's in Fresno) and it turns out I have a failed ABS pump. Although the replacement part is around $1700 plus several hours lagor to install and bleed, my Ducati Ever Red extended warranty is going to cover everything (minus a $50 deductible).
Although I didn't like paying for the warranty when I bought it, I am sure glad I did.
'08 CBR1000RR (2011-Present)
'08 1098S (2009-2011)
'07 ST3S (2008-Present)
'07 GSX-R750 (2007-2011)
'06 FJR1300A (2006-2008)
'01 ZRX1200R (2002-2008)
'92 DR350S (1998-2001)
'83 GS1100E (2001-2002)
'78 GS1000N (1979-1985)
'75 XS650 (1976-1979)
'72 CL125 (1974-1976)
Nomore76 is offline   Reply With Quote
Old Nov 23rd, 2011, 9:56 pm   #2 (permalink)
Spensersdad's Avatar
Images: 5
No doubt!
I purchased an extended warranty from Honda when I bought my VFR. It was my first fuel injected motorcycle and I was nervous about the expensive replacement cost of the electronic sensors and such. The five year coverage ran out years ago without me using it even once.
It's always a roll of the dice with those things, though. It can pay for itself with one repair, as in the case with your ABS, or you end up never needing it.
Michael
'07 ST3s ABS
'03 DR-Z400
'01 VFR800FI
Spensersdad is offline   Reply With Quote
Old Nov 27th, 2011, 11:04 pm   #3 (permalink)
I have to ask was there anything that could have avoided the failure? Did the dealer mention anything to you? I have to admit this is the first I've read about this failure. The only thing I have done was to change the pads, brake fluid and add speed bleeders about a year ago.
99 Nighthawk 750 (1st bike, sold)
06 ST3s
StuST3 is offline   Reply With Quote
Failure.... DreyeIce Vintage 2 Feb 22nd, 2011 6:47 pm
Bearing Failure briteyellowblur Sport Touring 20 Jan 14th, 2011 5:27 pm
Start Failure 748 Arai98 Superbikes 4 Dec 7th, 2010 1:16 pm
Battery failure CDONA HyperMotard 5 Sep 18th, 2009 3:35 pm
ECU Failure AlvaSpeed HyperMotard 44 Jul 13th, 2008 7:29 pm
