Plumbing GPS Cable - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 23rd, 2011, 8:15 pm   #1 (permalink)
waco748's Avatar
Plumbing GPS Cable
Looking for a source of switched power to connect a relay for GPS power. Would like to run the cable up the left side of the frame to the left grip but will take any recommendations for the right side or . . . . Wire color and location to tap the relay, please.
2006 ST3
Thanks, and Happy Thanksgiving!
Curt
2006 ST3, Termi and ECU
Always, ride safe!
Avatar credit: RD Key
waco748 is offline   Reply With Quote
Old Nov 24th, 2011, 12:08 am   #2 (permalink)
Ducati Designs
pgeller's Avatar
Images: 27
Theres a connector with switched power tied up under the instrument panel. It is supplied by a 5A fuse in the fuse box marked "grip heat". You don't need a relay to drive a GPS or other low-powered device.
pg
DD
pgeller is online now   Reply With Quote
Old Dec 2nd, 2011, 2:12 am   #3 (permalink)
waco748's Avatar
pg
DD
I found a schematic for my model year; grip heat should have brown/black wires. The search begins this weekend; thanks for the tip regarding grip heat.
Always, ride safe!
Old Dec 3rd, 2011, 7:04 pm   #4 (permalink)
waco748's Avatar
I tapped into the 5A grip heat fuse in the left-hand fuse box; switched power as advertised and routed to the GPS. Ram mount uses screws on the clutch lever mount.
Thanks for the help.
Curt
Always, ride safe!
Old Dec 3rd, 2011, 7:21 pm   #5 (permalink)
Lotus7's Avatar
I mounted my Garmin Zumo between the handlebars and powered it from the un-switched power available in the fuse box under the cowling. I find having the unit stay on when I turn off the bike more convenient. I don't like to have to wait for it to reboot when the bike is restarted.
Mike Schuyler
2004 Ducati ST3, 2000 Kaw W650, 1986 Yam TY350
Lotus7 is offline   Reply With Quote
Old Dec 4th, 2011, 6:19 am   #6 (permalink)
Life is too short to worry !
Gearbox's Avatar
But the zumo asks if you want to continue on internal battery when the ignition is turned off
Gearbox is offline   Reply With Quote
Old Dec 4th, 2011, 10:13 am   #7 (permalink)
waco748's Avatar
Same with the Nuvi; 3-hr battery life.
Always, ride safe!
Electrical Plumbing Info Gilly Hall of Wisdom 12 Dec 6th, 2011 11:20 am
Electrical Plumbing Info Gilly StreetFighter 14 Nov 1st, 2010 2:48 pm
Charcoal Cannister Plumbing redpato Supersport 2 May 8th, 2009 5:49 pm
Under seat oil breather plumbing twowheelcossack Superbikes 7 Apr 9th, 2007 1:55 pm
