Nov 17th, 2011, 5:42 pm
Cam Belt Tensioner Bearing Failure
During a normal service on my ST3 today, I found this cam belt tensioner bearing failure. Note the missing balls on the top of the bearing. Fortunately, the remaining balls remained intact. (click on thumbnail)
Has anyone else experienced this problem? The motor has 43,000 miles.
Ken Krumm
2004 Ducati ST3 43K - original owner
2004 BMW R1150GS 82k- original owner
1996 BMW R1100RT 137k - original owner
1996 BMW K1100LT 150k - original owner
2003 KTM 450EXC 6k
Iron Butt Association Member
Nov 17th, 2011, 6:20 pm
Lifetime Premium
The bearing on my '06 ST3s is sealed. Did your bearing ever have a shield? Did you locate any of the pieces?
Nov 17th, 2011, 8:41 pm
Both bearings are exposed on each belt. I just ordered a pair of bearings from Colorado Euro in Loveland for $16 each. If they are sealed, I will replace both of the outside bearings.
I didn't find any of the balls or other pieces when I removed the stock cam belt cover. I need to look more closely in the morning.
Ken Krumm
2003 KTM 450EXC 6k
Nov 17th, 2011, 8:46 pm
Damn, that's scary. Glad you found it before total failure.
Current Bikes: Aprilia RSV4 Factory for the street
'05 Honda CBR600RR Track Bike
"The trouble with internet quotations is that most are just made up" - Abraham Lincoln, 1864
Nov 17th, 2011, 9:05 pm
Moderator
All the belt rollers are sealed bearings on my 2005 ST3.
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
Nov 22nd, 2011, 7:32 pm
I received the new bearings from Colorado Euro and they are sealed. I found the exterior ring seals from the failed bearings.
I removed the bearings from the tensioner in the photo today and found the rear bearing froozen. The belt on the tensionrer is damaged on the backside since the bearing was no longer freely turning.
It appears to me that both belts were over-tightened by the dealer during the last service. Theres was no play between the bearings and the belt. It appears the over-tightened belts caused excessive heat in the bearing resulting in their failure. The other bearings on the horizontal clyinder still turns freely. However, the balls are exposed as well. So, I replacing all four bearings.
Removing the bearings required the bearing puller. Installing the bearings required a bearing tool setting device.
Ken Krumm
2003 KTM 450EXC 6k
Nov 22nd, 2011, 7:45 pm
Moderator
Did you hear any high pitched bearing whine beforehand? When I tension my belts, by hand, I warm the bike up very well and bring the revs up and down numeous times to see if the pitch changes. Too high a pitch after warm up, the belts are too tight. I agree, the belts may have caused the bearing to seize if they were too tight. And here I thought the bearings were a straight r&r. Thanks for the heads up. If I ever get a little extra money, it would be wise to order a set to have around.  Good thing you caught them on time.
Regards,
Nov 22nd, 2011, 9:58 pm
At 26,000 miles, my bike off of warranty burned out the $1100 speedo unit. My dealer warrantied the speedo on good faith. So as pay back, I let them do the service at 32,000 miles. The belts were changed then.
I didn't notice any noises out of the ordinary. However, when you throw in the normal motor noise, dry clutch rattle and I normally wear ear plugs, I may not have noticed. Only one of the four bearings were actually frozen. The other three still rotated.
Ken Krumm
2003 KTM 450EXC 6k
Nov 23rd, 2011, 3:21 am
Life is too short to worry !
I would be tempted to check the bearing numbers to ascertain whether they are the correct parts , if they are not maybe you can take it up with the dealer to explain why. Very lucky a belt did not let go.
Nov 23rd, 2011, 7:40 am
They were identical to the bearing that replaced them. Both were made in Italy and were the original bearings. So, maybe 43,000 miles is the life span of these bearings. I still think over-tightening the belts were the cause.
Ken Krumm
2003 KTM 450EXC 6k
