1999 ST front / rear teeth? - Ducati.ms - The Ultimate Ducati Forum
Old Nov 17th, 2011, 2:53 pm   #1 (permalink)
trader220's Avatar
Whats stock? For the front and rear?
Any real value in going to a 520 conversion?
Whats the suggested count from front / rear on a 1999 ST4 (NOT ST4S)
Thanks as always for all the great info I have been getting here!
1999 ST4
Lower Merion PA
trader220 is offline   Reply With Quote
Old Nov 17th, 2011, 2:55 pm   #2 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
All you seek is here:
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Nov 17th, 2011, 3:13 pm   #3 (permalink)
trader220's Avatar
The page wont download on my puter correctly.
Stock is 15/43? I would like some more low end so the question is do you drop to 14 in the front or go up to 44 in the back or both or some other combo?
Thanks
1999 ST4
Lower Merion PA
Old Nov 17th, 2011, 3:24 pm   #4 (permalink)
va duc's Avatar
Images: 12
I have an ST2, so I can't say for sure. I have experimented on mine and I ended up going up 1 on the rear. That gave me a little more on the low end without sacrificing highway riding.
I would try a 44 and cut a new chain to fit. I have a 45 tooth with only a couple hundred miles on it if you want to try it.
AMA Member
1998 Silver ST2$
Old Nov 17th, 2011, 4:50 pm   #5 (permalink)
Humble
Chuckracer's Avatar
Images: 2
Copied from the sticky at the top of this page: Sticky: Newbies, please read: Ducati Sport Touring Models
sprocket info
This was initially posted by someone else on another thread. I am reposting it here to try to keep this info in one convenient spot. I did not know there was an MY 01-ST4s, but that could be its release year in Europe.
Here's the info from Ducati's site regarding gearing. The first number is
the front sprocket size, the second number is the rear sprocket size.
Unfortunately, Ducati's site only goes back to 2001:
2001 ST2 - 15/42
2001 ST4 - 15/43
2001 ST4s - 15/40
2002 ST2 - 15/42
2002 ST4 - 15/43
2002 ST4s - 15/38
2003 ST2 - 15/42
2003 ST4 - 15/43
2003 ST4s (& ABS) - 15/38
2004 ST3 - 15/42
2004 ST4s (& ABS) - 15/38
2005 ST3 - 15/42
2005 ST4s (& ABS) - 15/38
2006 ST3 (& ABS) - 15/42
2007 ST3 (& ABS) - 15/42
Old Nov 17th, 2011, 5:21 pm   #6 (permalink)
va duc's Avatar
Images: 12
Must be a slow day for the mods.
AMA Member
1998 Silver ST2$
Old Nov 17th, 2011, 6:38 pm   #7 (permalink)
Humble
Chuckracer's Avatar
Images: 2
It's snowin. Expect me to be everywhere on here for a while.
Old Nov 17th, 2011, 6:43 pm   #8 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
It must be snowing in VA, 'cause she looks kind cold.
Oh no, Mr Chuck-the-eraser gonna see that.
Have a good one.
tony b
2001 ST4
tonered is offline   Reply With Quote
Old Nov 17th, 2011, 7:05 pm   #9 (permalink)
Humble
Chuckracer's Avatar
Images: 2
E-raser like it.
Old Nov 18th, 2011, 3:19 am   #10 (permalink)
MarkST's Avatar
Yes stock is 15/43.
14 on the front is a fantastic arrangement - it will give you what you want. It really makes a huge difference, and it is relatively cheap and easy to do.
Going up on the back will achieve the same result, but means more expense buying a larger sprocket, and you will also probably need to buy a longer chain too.
Try a 14, you won't be disappointed, and if you are you can just send it to me and I can experience the undisappointedness for you....
MarkST is offline   Reply With Quote
1996 & 1999 front wheel Skyking2 Supersport 5 Aug 2nd, 2011 8:36 am
ST3 Front Sprocket Teeth Are Bent. strider3 Sport Touring 9 Apr 1st, 2011 9:37 am
1999 750ss front fork octanepower Supersport 2 Oct 1st, 2009 11:07 am
How to tell if my STM clutch is 12 teeth or 48 teeth neveradullmoment Superbikes 5 Sep 12th, 2009 2:50 am
stock teeth on 998 rear sprocket? epx666 Superbikes 3 Jan 16th, 2006 3:12 pm
