intensive ST2 maintainance
greetings Ducatisti,
I'm a Duc owner since 2000.My 996 is WILD,built most of it myself,including Pistal re-machinings.THat tells a little of skill level.
My '02 ST2 i bought March of 2009 had 9k miles.It now has 14k miles and i know it needs maintainance.Currently the frame is removed/stripped.Wiring harness entirely removed to check thouroughly.My local Ducati dealer just cancelled my order for the service manual stating out of print.The ST2 is very similar to my 996 so i think i can WING it.
The belts posess ZERO tension.I mean silly flapping loose.Having tensioned 7 sets of belts in 21k miles on the 996 this ST2 loose condition is alarming.I use the Lowener/Ducati tension gage with proficiency and like it.I also discovered i'd (back in 2002) bought the conversion kit to use it on 2 valvers.Who'd a thunk back in '02...
What i desperately NEED is the SPECS.How do i position the gage on the ST2 belt and what is the gage setting,2.5 is the 996 spec.And on the 996 the gage positions between the DOHcams.Also,HOW do i lever the tensioner? Is there a special tool?
My valve clearances are consistent at .005"-.006" on BOTH openers and closers.
I'd also like to separate the swingarm(grease) but it seems a press fit.
THe bike had a gremlin where...on a day long ride it would occasionally lose ALL power.Always briefly for several seconds.It was startling to be on hard accell passing traffic and suddenly NO GO.
I haven't found and bad wiring yet.I DID dismantle the fuel pump and found piles of rust under the pump mesh pick-up as well as all over the pump base.Found a Split hose on the air separator.
I've been hanging around here lurking a few months contemplating my questions.
Can i get some assistance please?
Thanks
'99 Buell X1 (Yellow)
'00 996Bip (Yellow,BST,modified engine)
'02 ST2 (Red..New to me 4-10)
'05 Buell XB12r (Red)
