SSSA on an ST - Ducati.ms - The Ultimate Ducati Forum
Old Nov 13th, 2011, 2:02 am   #1 (permalink)
cb4265's Avatar
SSSA on an ST
Does a Monster S4R swing arm alter our wheelbases, are they the same or different?
Craig
I'll try to be nicer, if you try to be smarter.
R.I.P. #58
WLF ViVa La Figa
2002 ST2 RED
STAINTUNE Stainless Steel Pipes
MICHELIN PILOT ROAD 3's
http://www.youtube.com/watch?v=wDMlso1fUYY
cb4265 is online now   Reply With Quote
Old Nov 13th, 2011, 7:34 am   #2 (permalink)
guido's Avatar
Hello
Pretty much the same, if there's any difference it doesn't appear any greater than what's available in the chain adjustment mechanism.
I'm only stating that because I assembled my "dry-run" bike with the chain from a DSSA.
FWIW...
guido in Houston
'03 sT4s ABS (sport TOUR)
'02 St4s (SPORT tour) w/ MBP Testarosso heads, DucShop Crank w/ Carrillo Rods, Pistal Pistons
'05 S4R - Work in Progress
'07 S4RS - Work in Progress
'03 ST4S-RS Moving past conceptualization......
'80 BMW R1050S Hybrid Cafe (gotta get back together soon...)
"It ain't really "yours" until you've MODIFIED it!"
guido is offline   Reply With Quote
Old Nov 13th, 2011, 7:47 am   #3 (permalink)
MarkST's Avatar
I've just had a measure up for you Craig.
From the centre of the swinger pivot on my standard ST4 swinger to the centre of the adjustable axle hole is 520mm.
On my S2R/S4R SSSA the measurement is exactly the same to the central point of the eccentric hub adjustment, just confirming Guido's thoughts..
MarkST is offline   Reply With Quote
Old Nov 13th, 2011, 10:12 am   #4 (permalink)
what kind of modifications would you have to do to fit the new swingarm on an st?
1998 ST2
Rev. Dr. Moses P. Lester is offline   Reply With Quote
Old Nov 14th, 2011, 8:07 pm   #5 (permalink)
MarkST's Avatar
The swinger is a direct replacement.
Moses/Craig, the exhaust from the rear pot won't go down through the S*R swinger, so that will have to be modified/re-thought.
Also the Sachs rear shock with the piggyback reservoir won't work either, as the reservoir will foul on the S*R swinger bracing. The Showa unit and the ST4s Ohlins unit (both with a remote reservoir) will work fine.
Old Nov 14th, 2011, 11:59 pm   #6 (permalink)
You need all the sssa parts from the pivot back, chain guard,fender/hugger,axle,rotor,caliper,hub,sprocket,wheel, the whole bunch and I also used the S2R rearsets.
danrduc is offline   Reply With Quote
St2 sssa ? Ed B Sport Touring 1 Aug 20th, 2011 4:48 pm
Vee Two 999 SSSA BrianG Superbikes 10 May 24th, 2011 11:18 am
749 and sssa dicduc Superbikes 5 Jan 15th, 2008 6:39 pm
Sssa j1b3h0 Sport Touring 0 Sep 8th, 2007 4:12 pm
999 w/ 916 SSSA conversion Bella749 Superbikes 2 Aug 25th, 2007 8:55 pm
