St2 revving up to 10000rpm by itself - Ducati.ms - The Ultimate Ducati Forum
Old Nov 8th, 2011, 1:39 am   #1 (permalink)
Hi all have had an issue with this bike for 4 years now. It has been to 6 diff bike shops including ducati sspecialist and still can't be fixed. Ok detail bike is ducati st2 97 model. Problem I'm having is bike starts fine and idles fine. Revs upto 2500 rpm fine then once you go over 2500 rpm it jumps to 10000rpm by itself without moving throttle. It then comes back to idle. Very scary to ride when it happened. So far iv been told it's valves so had them done then told it was low on compression, don't no how this would make it free rev. Any advice would be great.
Campbell83 is offline   Reply With Quote
Old Nov 8th, 2011, 1:58 am   #2 (permalink)
cb4265's Avatar
Has to be electrical rather than mechanical doesn't it?
I didn't know they would rev that hard, bloody impressive really!
How do you knock the revs back when it revs to 10k by itself?
Craig
I'll try to be nicer, if you try to be smarter.
R.I.P. #58
WLF ViVa La Figa
2002 ST2 RED
STAINTUNE Stainless Steel Pipes
MICHELIN PILOT ROAD 3's
http://www.youtube.com/watch?v=wDMlso1fUYY
cb4265 is online now   Reply With Quote
Old Nov 8th, 2011, 2:06 am   #3 (permalink)
Hi the revs drop back down by itself but is slow then as soon as you rev it to 2500 rpm it does it again. Im also thinking electrical. When it happened I was riding back from a trip had done about 200 kms then it started doin this. I'm thinking computer but don't want to waste more money until it can be verified as iv spent 7 grand so far for the same results
Old Nov 8th, 2011, 2:12 am   #4 (permalink)
Puffin64's Avatar
Is your ECU chipped? if so could you put back the original chip?
I'm sure it's the ECU, your best bet would be to buy a cheap one off ebay or a bike breakers parting out one.
Tim
ST2 1998 custom
Puffin64 is offline   Reply With Quote
Old Nov 8th, 2011, 2:12 am   #5 (permalink)
latte committee's Avatar
Motorcycles are by nature ,,,,,, FEMALE
Your ST2 has obviously had a dummy spit at being upstaged by the later model, faster woman (ST3), that you've introduced to garage.
"She's" only revving to 10 grand to remind you that she's still got what it takes, and like most females ,,, does it randomly, and when you least expect it.
Ride it like you stole it
Invest in eDUCATIon
2007 ST3, wiff lotsa tricky bits.
latte committee is online now   Reply With Quote
Old Nov 8th, 2011, 2:14 am   #6 (permalink)
Hi no ecu is not chipped. I was thinking ecu but not sure. So can I just put a chip in it
Old Nov 8th, 2011, 2:18 am   #7 (permalink)
So true about the female lol
Old Nov 8th, 2011, 2:23 am   #8 (permalink)
On a more serious note .........
The cause HAS to be an electrical influence upon FUELING.
An engine does not rev on electricity alone.
The only thing that increases engine RPM is additional fuel/air mixture.
Which it gets via information input to the ECU from other sensors, which inturn results in greater fuel delivery.
If it got only additional fuel, but no additional air/oxygen, then it would flood, wet the plugs, and stop.
So I'd be looking at -
TPS
Throttle bodies
Air bleeds.
It's gotta get a HEAP more Air/Fuel, in the correct proportions to rev to 10 grand.
10 grands worth of fuel, without 10 grands worth of air, will only flood the engine, NOT increase it's output (revs).
Go looking for things that have a causal relationship to both requirements.
Invest in eDUCATIon
Old Nov 8th, 2011, 2:33 am   #9 (permalink)
Ok I'll check tps now once I work out how and let you no
Old Nov 8th, 2011, 3:37 am   #10 (permalink)
Still needs a life.
Bill_Anderson's Avatar
Images: 19
No governor on the ST2? I don't think an ST4/4s or ST3/3s could make it up to 10,000 rpm as the governor would kick in.
Revving in Neutral/Without Load? Vegas. Superbikes 17 Jun 10th, 2010 8:26 am
Revving Issues! dwnhillskater Superbikes 22 Jan 8th, 2009 10:11 pm
No Revving of Motorcycles at Indy during MotoGP call911mfc Ducati Motorcycle Chat 24 Aug 15th, 2008 12:49 pm
'Rough' spot when revving 848 engine hawc Superbikes 6 Apr 20th, 2008 8:39 pm
748 revving issue Ralphmouth Superbikes 6 Jul 30th, 2007 10:40 pm
