Bike trip tomorrow - speedo not working, engine light on! - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 4th, 2011, 9:18 am   #1 (permalink)
Yesterday I took the fairings off to check the bike over ready for a 1 week bike trip. At the same time I installed the Desmo Times fan and manual override switch plus a "Powerlet" power outlet inside the fairing wired to the battery. During the operation I disconnected the battery and of course had to disconnect and reconnect the instrument cluster. After I had reassembled everything the bike checked out all ok. Today when I rode the bike, after about 15 mins all of a sudden the speedo dropped to zero, the check engine light is illuminated and the ABS light is up. Apart from that the bike runs fine.
I disconnected and reconnected the instrument cluster however problem does not go away. The connection looks very clean so I did not clean it with anything (eg. contact cleaner etc). I have many years experience at automotive and industrial electrical wiring so the job was performed properly.
Does anyone have experience with solving a similar problem, I would especially like to know as I am about to depart on a 1 week bike trip tomorrow with my father (he is 75 and still loves bikes and is very fit) + my mate.
I plan to take the bike to a dealer to see if they can held relieve me of some of my money however not sure if they an assist me as they will most likely say "book it in for next week". Should I ride the bike in this condition?
Phil - Pilbara Duke
2006 ST3s (red)
2008 KTM 530 EXC
2006 Honda CRF250x
Pilbara Duke is offline   Reply With Quote
Old Nov 4th, 2011, 9:25 am   #2 (permalink)
DuckMan's Avatar
Did you check the front wheel abs/speed sensor?
Mike
DuckMan is online now   Reply With Quote
Old Nov 4th, 2011, 10:16 am   #3 (permalink)
My nearly brand-new '06 ST3 had the same problem after 200+ miles. Rode another 1000 miles, no issue.
Took it in a few times. We started with securing the electrics to the computer with special electrical spray, etc. Didn't work. Then, we took off the rear sensor, cleaned it, and used the same spray. Additionally, we found that Ducati had installed a very thin shim between the sensor and the mounting in the rear. We removed the shim, problem solved! It was just too far from the pick-up and not reading, causing the error.
Good luck!
Bugsy
  • 2006 ST3
  • 2007 Daytona 675
  • 2009 Bonneville
  • 2007 R1200GS
jazzgangsta is offline   Reply With Quote
Old Nov 4th, 2011, 8:03 pm   #4 (permalink)
Thanks for the excellent feedback, sounds very logical what you say, I should have thought of that. Pulled the fairing off again! Cleaned both front and rear speed pickup connections with contact cleaner and a fiberglass brush. Problem still there. Comes up with the check engine light soon as the ignition is turned on. Looks like I will ride on regardless and sort it out when I get back.
Phil - Pilbara Duke
2006 ST3s (red)
2008 KTM 530 EXC
2006 Honda CRF250x
Old Nov 4th, 2011, 8:37 pm   #5 (permalink)
Put a piece of electrical tape over the engine light and call it good.
98 ST2 - STILL stumbles like a drunkard
Ducologist is offline   Reply With Quote
749 Tach and Speedo stopped working lrrs428 Superbikes 5 Nov 15th, 2009 6:00 am
how does the bike read the mileage on a sport classic? digital, engine, speedo cable? 370ZRR Sport Classic 2 Oct 6th, 2009 1:10 am
speedo not working scott748mono Superbikes 1 Sep 12th, 2007 10:13 pm
749 speedo not working yellowzx Superbikes 2 Jun 8th, 2007 11:00 pm
748 speedo was working then stopped working. zerofighter Superbikes 2 Apr 14th, 2007 1:27 am
