Battery Tender-- Normal? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 2nd, 2011, 11:14 pm   #1 (permalink)
After our halloween snow storm I started to stage my bike in the garage (with hopes to ride again this month if temps and wet leaves allow)
Anyhoo
Hooked it up to a Battery Tender (one of the supposed smart ones) and I have noticed that it goes from steady green (all good ready to go) back to a flashing green (80% charged and still charging)
So, is this normal? If so what is causing the battery to dip down go back up and down again? Esp if its just sitting there?
2002 ST4S (2011-)
1977 Triumph (2000-)
2001 Triumph ST (2003-2011 RIP)
Kierantaylor is offline   Reply With Quote
Old Nov 3rd, 2011, 12:17 am   #2 (permalink)
Spensersdad's Avatar
Images: 5
I have a Battery Minder. That is the actual name, not a generic description.
If my battery is a little depleted the green light glows solid. Once the battery charge is up the green light flashes, this indicates a float mode.
Michael
'07 ST3s ABS
'03 DR-Z400
'01 VFR800FI
Spensersdad is offline   Reply With Quote
Old Nov 3rd, 2011, 12:47 am   #3 (permalink)
I have a Battery Tender Jr. and once mine hits solid green, it stays solid green. Perhaps the battery is reaching the end of it's lifespan.
98 ST2 - STILL stumbles like a drunkard
Ducologist is offline   Reply With Quote
Old Nov 3rd, 2011, 3:43 am   #4 (permalink)
Still needs a life.
Bill_Anderson's Avatar
Images: 19
My Battery Tender does the same thing.
Old Nov 3rd, 2011, 6:00 am   #5 (permalink)
Stick's Avatar
Be sure that nothing is turned on, like heated grips that can accidentally be left on, if wired direct to batt. IF the battery was low, it's not uncommon for them to cycle from float back to charge for a while, but if it's constantly doing it, I'd be looking for a parasitic drain, or the above.
Michael:
Your Battery Minder, when it's flashing, not only goes into the float mode, but it also goes into the desulphation mode. I have one, and it's the best tender that I've used to-date. I've actually seen a slight amount of that whitish looking crud on the plates of a wet cell battery vanish, while using this Batt.Minder (over a couple of months).
Stick
Other brands (past):
Old Nov 3rd, 2011, 8:45 am   #6 (permalink)
As someone else mentioned the blinking green indicates the battery is charged and the charger is in maintenance mode. At some point the green led stays on solid indicating full charge has been met.
RDuc3 is offline   Reply With Quote
Old Nov 3rd, 2011, 8:54 am   #7 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
I believe that I read somewhere that the Battery Tender will cycle every 48hrs. I could be full of it though.
Have a good one.
tony b
2001 ST4
tonered is offline   Reply With Quote
Old Nov 3rd, 2011, 8:58 am   #8 (permalink)
Stick's Avatar
I've had some of the Schumacher brand (Wally Mart) 1.5A tenders do weird things. I use these on a 24 hr. timer. They come on at 4AM, so it's "ready" for me at 5:30.
I think they go off around 8AM. 4 or 5 hrs. of trickle/float works 4 me. My 'vette battery lasts over 10 years doin' it this way!
Stick
Old Nov 3rd, 2011, 2:24 pm   #9 (permalink)
I have a Battery Tender JR and it does not blink. I also have a couple of older Battery Tenders that don't blink either, just the newer ones do I guess.
Old Nov 3rd, 2011, 2:25 pm   #10 (permalink)
Official Sponsor
motolectric's Avatar
Yes, it is normal. The ECU draws a few milliamps at all times and eventually that draws the battery down enough to trigger the charger to come back on and top it up.
That's the big breakthrough with "tender" type chargers.
Prior to this type you either had tickle chargers which forced current into the battery at all times (and boiled wet cell batteries dry over time) or chargers that would shut off at full charge but not come back on.
I have a Sears brand charger from +20 years ago which was one of the first of the tender type and it was over $100 back then.
But it still works and does the job well.
But I also have 3 other tender type chargers since some batteries need a charger with specific characteristics (Odyssey etc.).
HTH
Michael Heth
mheth@motolectric.com
Motolectric.com | Innovative Electrical Upgrades For Motorcycles Since 2002 |
Also available through Motolectric | Remus - Melvin - Odyssey - Shorai - Magnecor - Scotts Dampers - Traxxion Fork Upgrades - TFX Custom Shocks |
motolectric is offline   Reply With Quote
Battery's so dead, Battery Tender will not charge it... Tag Sport Classic 11 May 29th, 2011 3:31 pm
What's up with Battery Tender? Nashduc Sport Touring 28 Jan 30th, 2011 7:09 am
Battery Tender DanF Multistrada 7 Sep 7th, 2010 12:03 pm
Which Battery Tender? NYSport HyperMotard 11 Nov 30th, 2008 3:30 pm
Battery Tender Nomore76 Sport Touring 10 Mar 6th, 2008 6:15 am
