Power Commander ST2 - Ducati.ms - The Ultimate Ducati Forum
Old Oct 27th, 2011, 4:05 pm   #1 (permalink)
Power Commander ST2
Hi Folks. Does anyone know if and what power commander/ aftermarket chip would fit a 2003 ST2 ? (Preferably programmable) I've been on the PC website and couldnt find one to suit an ST2. Thanks for any help
KiwiSt2 is offline   Reply With Quote
Old Oct 29th, 2011, 5:12 pm   #2 (permalink)
Kiwi, there is no PC for the ST2. Ducati used to have a performance chip (not sure if it is still available), FIM had one (ditto), FBF had one as well. Do a search here to see what might be available still or contact Ducati tuners in NZ. You might also have luck with mbpducati.ca if you want to import from Canada.
Cheers;
Les
2002 Ducati ST2
1974 Norton Commando
1972 Norton Commando
Lesco is offline   Reply With Quote
Old Oct 29th, 2011, 6:04 pm   #3 (permalink)
This might be a wild goose chase or a good lead...
The original owner of my '98 ST2 put a Fast By Ferracci chip and pipes on it. Then he took it to Dyno Solutions in Brookfield CT (Dyno Solutions - Home) for a Power Commander PC III USB and custom chip mapping. It might be worth checking with the company to see if they're still involved with Ducs and can tell you anything useful. I can also check with the PO and see what he can tell me.
'98 ST2, '75 Norton Mk III
ptourin is offline   Reply With Quote
Old Nov 3rd, 2011, 8:11 am   #4 (permalink)
Stick's Avatar
I'm 98% sure it's the same PCIII that used for the ST4s. It should "Plug and Play" on a ST2. It just plugs into the injector connectors, and the TPS (and a ground wire).
I know there's a gent in here with one on his ST2, but his PM is full, hence cannot send him a PM !! I was just trying to verify the PCIII model number.
here it is, read the 1st post, last paragraph:
Recommended Shift point on 98 ST2 :
>>>98 ST2 that has always run Mobile 1 and currently has 26,000 miles on it. The only engine related mods are a Power Commander and D&D slip ons<<<
"Don't make one for the ST2" -- well, the ST4s isn't listed, either, but we use the one for the SR4 Monster.
Stick
Other brands (past):
749 power commander map. bmxer4liffe Superbikes 1 Apr 28th, 2011 2:22 am
Power Commander Map 748 74eight Superbikes 2 Apr 10th, 2009 6:14 pm
Power Commander for ST-2 tw60180 Sport Touring 5 Oct 14th, 2008 11:44 am
999 & Power Commander 3 SAC Superbikes 5 Jun 29th, 2008 3:33 pm
Power commander Lync Monster 0 Feb 3rd, 2007 6:50 am
