Oct 25th, 2011, 6:14 am
Do ECUs, just 'go'?
Hi Guys,
My ST4s is very poorly and wont start.
Turns over but just wont fire up.
Its had a new CAS and new battery but no joy.
This happened quite suddenly.
Do ECUs just fail with little warning?
I've found someone who'll check it but its £70 which I thought was quite a lot just to plug it in.
Suggestions or help most welcome.
Tim
2002 St4s, in yellow, all the touring gear, top box and panniers. My first 'big' bike, and I'm lovin' it.
Oct 25th, 2011, 7:40 am
Ecu
The one on my 900ssie was hit or miss for a few months before it went, cost to test and repair my old one was £210 , a member of the DOCGB sold me one for a good price.
May we never grow old to have FUN
Oct 25th, 2011, 10:14 am
What is!
What is a CAS ?
2007/ducati-ST3-S-ABS 2002-Honda 250
Oct 25th, 2011, 12:20 pm
Ducati Designs
I think he meant "CPS" (crank position sensor), same idea as crank angle sensor on some cars.
2002 ST4S ecus had some reliability issues, although a lot of them failed after running, or would not restart when hot.
You need to make sure the CPS gap is set correcly; this is noted in the service manual. There are shims under the sensor that you can swap around to set the gap. Too wide a gap and it won't detect properly. Too close and it can get ground down.
A thorough check/clean/dielectric grease of all connectors, relays, grounds, etc. is always a good idea periodically.
pg
DD
Oct 25th, 2011, 4:46 pm
Originally Posted by TT Tim
Hi Guys,
Tim
Tim,the P/O of my 02 ST 4s had 3 ECUs replaced under warranty,this one seems to be doing fine, for the last two years,no problems,although I dont want to be riding to far from home,sort of warey about being stranded in the desert,500 miles from a dealer,there was obviously some problems with theseECUs.How about a "reflash",dont know much about that,but they can be reprogrammed,I guess ,Cheers,Dave
Oct 31st, 2011, 1:05 pm
2002 4s ECU
I have an 02 4s as well. I purchased a "brand new" reflashed ECU from Houston Superbikes for $495+ shipping before I identified my problem as fuel.
This has never been on a bike and is the stock map w/o imobilizer.
Been waiting reach "30 posts" before forum will let me post something for sale??
If interested I'll sell it for $350usd.
PM me if you want it.
Thanks
Travers
