Oct 24th, 2011, 10:47 pm
Mounting zumo on steering stem nt
Hi all
I have the zumo and the Steering Stem Nut with Ram Ball from desmotimes seems to be the best mounting solution.
I would rather not throw $35 for a tool to switch these out. So- does anyone in boston ares have said tool?
Or if not, is there a workaround to pull the nut?
I am not trying to skip paying desmotimes-- I am ordering a crapload of other stuff but would love to save the 35 for a handle of stoli..
Kieran
2002 ST4S (2011-)
1977 Triumph (2000-)
2001 Triumph ST (2003-2011 RIP)
Oct 25th, 2011, 5:20 am
I work in Wilmington and have a tool you could borrow.
Oct 25th, 2011, 5:31 am
I have the tool as well you could borrow, but live further away. I will add that it is really worth buying the tool as it is also a maintenance item to check the head bearings for proper tightness. This is especially true if your bike still has the OEM caged ball bearings. Check eBay. They are listed there a lot, along with some other inexpensive items for maintenance.
Here's a link to the tool for less than $20.00 shipped.
DUCATI STEERING STEM NUT TOOL..... DUCATI 748 | eBay
Also search "ducati tools" under eBay motors for more.
Dan.
A man said to the universe:
"Sir I exist!"
A sense of obligation."
Stephen Crane
Oct 25th, 2011, 10:35 am
I have tried two other routes.
A - The 1” ball that fixes to the handlebar nuts.(pictured)
B- Take said item in A and fix with a nut through a hole drilled into the yoke nut. A little tricky but using socket extensions like a chimney brush means you can hold the nut on the back
John
2002 ST4S
Reality is an illusion caused by a lack of alcohol
Oct 25th, 2011, 11:56 am
Life is too short to worry !
I also use method B which costs minimal however the yoke tool is necessary for torqueing the head bearings as stated above so a worthwhile addition to the toolbox.
Oct 25th, 2011, 12:29 pm
2003 ST4s
some other bikes too
.. and some other bikes but I sold them
Oct 25th, 2011, 1:34 pm
If you are careful you can drill the hole in situ and then pass the nut up inside the headstock to connect with the ram mount
John
2002 ST4S
Nov 3rd, 2011, 12:08 am
fantastic forum and thanks for tips-- I will buy the tool and get 'er done this winter. Love getting lost on odd roads and having the gps save me from short term mammaries ; )
2002 ST4S (2011-)
Nov 3rd, 2011, 3:46 am
Still needs a life.
For those who have not yet bought a mount, check out the one by Ducati Designs. No special tools are needed for installation.
Ducati Designs, LLC - Mini Mount ST
