Sprung a leak… - Ducati.ms - The Ultimate Ducati Forum
Old Oct 21st, 2011, 2:31 pm   #1 (permalink)
trader220's Avatar
Sprung a leak…
After I changed the oil I now have two leaks. I torqued the drain plug to 31 foot pounds. I tightened the filter as much as I could. I now have a leak from both spots. New crush washer in the plug too.
Suggestions?
1999 ST4
Lower Merion PA
trader220 is offline   Reply With Quote
Old Oct 21st, 2011, 2:41 pm   #2 (permalink)
Might be just from the filter, a little tip is to oil the seal of the filter with some new oil. I also give it a little nip with a strap wrench as normally my hands are oily!!
John
Ducati ST4S 2002 "Bitch"
Ducati ST2 2002 " Scarlet"
Yamaha DT175MX 1983 "Yasmin"
mw0dbb is offline   Reply With Quote
Old Oct 21st, 2011, 2:50 pm   #3 (permalink)
trader220's Avatar
Did both of those
1999 ST4
Lower Merion PA
Old Oct 21st, 2011, 3:10 pm   #4 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
Did the old gasket from the filter come off, or is it still in there? I have seen it happen!
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Oct 21st, 2011, 3:26 pm   #5 (permalink)
trader220's Avatar
off
1999 ST4
Lower Merion PA
Old Oct 21st, 2011, 3:58 pm   #6 (permalink)
va duc's Avatar
Images: 12
I have also seen the gasket not seated properly on the filter, you might put the bike on the side stand and remove the filter to check it?
AMA Member
1998 Silver ST2$
Old Oct 21st, 2011, 7:30 pm   #7 (permalink)
You tightened the filter as hard as you could? normally I just go hand tight on oil filters. With the ST2 I use the Fram filters with the hex head - since I can't really get my hand on the filter I go hand tight at the bottom, then an extra 1/4 turn with the wrench. I found through trial/error that you need to take a paper towel and wipe dry up inside the engine block, where the filter gasket goes against. You just need to smear little bit of oil around the gasket. You may have buggered the gasket up by over-tightening, if the steps above don't work take the old filter gasket and use that.
Not sure what to tell you if the oil plug is leaking too, 31 ft lbs is the correct torque - only thing I can suggest there is a new crush washer.
1998 ST2
erikrichard is offline   Reply With Quote
Sprung a leak!!! drdavis74 Sport Classic 17 Oct 13th, 2010 4:34 pm
Spring has sprung.. I have a itch to mod... theduckllr Sport Classic 2 Mar 3rd, 2010 12:41 pm
Captain, we've sprung a leak an' i can't hold'r! KoiHoshi Supersport 5 Dec 24th, 2009 6:41 pm
Dang I sprung a leak in the clutch master. DMCTRUBY Superbikes 8 Sep 19th, 2008 4:31 pm
ST's Softly Sprung? TZ250 Sport Touring 7 May 22nd, 2006 10:04 am
