Cold weather running - Ducati.ms - The Ultimate Ducati Forum
Old Oct 21st, 2011, 12:59 pm   #1 (permalink)
I'm wondering how others bikes run in the cold. As the temperatures have been dropping, my ST2 has been running quite a bit better. At 40 deg F, the front tire comes off the ground under normal acceleration without dropping the clutch. That just does not happen when the temperatures are warmer. I'm wondering if this is typical for others.
98 ST2 - STILL stumbles like a drunkard
Ducologist is offline   Reply With Quote
Old Oct 21st, 2011, 1:23 pm   #2 (permalink)
Shazaam's Avatar
Sure. The cooler denser air will supply more oxygen and you'll get more fuel when the air temperature sensor signals the ECU to supply more fuel. More fuel plus more air equals more power.
Old Oct 21st, 2011, 5:51 pm   #3 (permalink)
Still needs a life.
Bill_Anderson's Avatar
Images: 19
Your gas mileage will drop, however.
Old Oct 22nd, 2011, 12:30 pm   #4 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
It depends. Once it gets too cold, the engine won't stay warm enough. I usually add some duct tape to the right side of the radiator in the winter when the throttle response drops off.
Yes, though. Fall is primetime riding weather and scenery.
Have a good one.
tony b
2001 ST4
tonered is offline   Reply With Quote
Old Oct 22nd, 2011, 11:24 pm   #5 (permalink)
Sweet. I didn't realize the ECU factors in air temp. Thought it just looked at pressure. Suddenly turbo intercoolers make a lot more sense.
Old Oct 25th, 2011, 10:45 am   #6 (permalink)
Stick's Avatar
5 "gazintas" for the older ECU's:
TPS
Barometric pressure
Air Temp
Engine (coolant) temp
Engine position (timing/RPM)
Add O2 on the newer machines for the 6th input.
Stick
Other brands (past):
Old Oct 25th, 2011, 11:53 am   #7 (permalink)
MTScott2's Avatar
Images: 5
Bonus there is less mosquitos out there too!!!
2011 Red Multistrada Touring
Old Oct 25th, 2011, 10:43 pm   #8 (permalink)
And your probably running a bit rich in the warmer temps, the mapping or set up not being perfect.
danrduc is offline   Reply With Quote
How cold is too cold for the engine running temperature? TwistiesAllDay Multistrada 48 Nov 28th, 2011 8:55 pm
Cold weather 996 questions badger Superbikes 2 Nov 2nd, 2010 11:20 am
Cold weather question IlMostroNero Monster 4 Feb 2nd, 2010 5:26 pm
Cold Weather Driving Me Mad BellaCorse Sport Classic 19 Apr 9th, 2007 8:09 am
Cold weather? Ha! I still ride. MyIronLung Ducati Motorcycle Chat 20 Oct 12th, 2006 1:07 pm
