First 2k miles done, doing an oil change and have a question. - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Oct 18th, 2011, 4:15 pm   #1 (permalink)
trader220's Avatar
Okay I am just about at my first 2k miles on the 1999 ST4 I picked up a couple of months ago. Dodging the nasty rain we have had here for months got old. If I have time tonight I will do my first oil change on this bike, not my first oil change ever.
Couple of easy questions:
Do you change the crush washers on the both the plug and the screen each time?
Obviously I will remove the fairing to be able to get at the screen and pull it all the way out. There are two bolts, the head on the main one is horizontal and obviously faces out so you can access it and pull the screen all the way out. There is a small one which faces down towards the ground and I assume it’s a tension bolt to lock the horizontal bolt in place. The question is, do you always clean this screen each time you change the oil and is my assumption on the bottom bolt correct in that I would need to remove it in order to remove that screen.
Thanks as always.
1999 ST4
Lower Merion PA
trader220 is offline   Reply With Quote
Old Oct 18th, 2011, 4:23 pm   #2 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
No reason to remove the bottom bolt, I would check the screen as the bike is new to you. I check mine every other time I do an oil change. Just reuse the crush washers, maybe get a new one once in a while.
Also there is no reason to remove the fairings for this. I remove the mid fairing screw that holds the faring to the bike right above the clutch, you can manage by just pulling it out slightly to get at everything you need to, unless you just enjoy unnecessary pain.
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Oct 18th, 2011, 4:31 pm   #3 (permalink)
trader220's Avatar
Cool, thanks for the advice. I was basically going to skip the screen if I had to pull the fairing.
So what does that bottom bolt hold?
1999 ST4
Lower Merion PA
Old Oct 25th, 2011, 10:39 am   #4 (permalink)
Stick's Avatar
That bolt is a "cork". It's used to facilitate machining the oil port (galley) that's on the opposite side of the large hole. You can see this hole if you use a flashlight, look into the screen's bolt threaded area, and look up (your head should be on the floor at this point!) Best not to disturb that bolt. It's just a bolt with a crush washer.
Reagarding the fairing...you should remove 2 of the belley bolts that hold the right lower to the left lower, in addition to the large bolt near the clutch. Roll of ductape will help keep the fairing flexed outward...
Stick
Other brands (past):
Old Nov 3rd, 2011, 11:14 am   #5 (permalink)
@220, what did you find out about the oil consumption issue you had a while ago? Any conclusions?
2003 ST4s
what broke now is offline   Reply With Quote
Old Nov 3rd, 2011, 12:22 pm   #6 (permalink)
Life is too short to worry !
Gearbox's Avatar
What issue
Gearbox is offline   Reply With Quote
Old Nov 3rd, 2011, 3:25 pm   #7 (permalink)
Originally Posted by Gearbox View Post
What issue
This one>
Oil Consumption?
maybe I missed the outcome posted someplace else, if so my bad.
2003 ST4s
Old Nov 3rd, 2011, 4:01 pm   #8 (permalink)
Bun-bun's Avatar
Thanks as always.
Since questions are being asked about the screen, I'll be so bold as to ask one of my own. . . What size is the allen key for the screen on my '02 ST4s?
Thanks.
2002 Monster 620ie (used to be ) Dark
2002 ST4s
Bun-bun is offline   Reply With Quote
Old Nov 3rd, 2011, 4:05 pm   #9 (permalink)
trader220's Avatar
I was mistaken in the amount and I am just monitoring to see if there is any significant changes
1999 ST4
Lower Merion PA
Old Nov 3rd, 2011, 4:08 pm   #10 (permalink)
Bun-bun's Avatar
Thanks.
Ne'mind, 14mm.
2002 ST4s
First Oil change 600 miles or ? catbeaver Multistrada 7 Aug 13th, 2009 6:30 pm
First oil change at 1700 miles! JohnE1000 Ducati Motorcycle Chat 4 Jun 16th, 2009 8:41 am
1st Oil Change Help - 600 miles Navigator HyperMotard 30 Jan 4th, 2008 7:01 pm
14T With 3000 miles, Change to 15T? Duc-OT Sport Touring 3 Aug 2nd, 2007 6:50 pm
Anyone in here only does oil change/maintenance every 6k miles? ducatiti Supersport 17 Aug 27th, 2006 7:23 am
