ST2 upper triple - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Oct 18th, 2011, 1:47 pm   #1 (permalink)
ST2 upper triple
Hey guys, I am picking up a 99 ST2 this weekend and I am curious if a monster 696 top triple will fit this bike? I have a brand new set of easton bars that I want to use and that seems like a good way to get them on there.
Has any one installed any monster top triple to the ST2 to utilize a standard bar?
Thanks
Andrew
Andy
GC8andy is offline   Reply With Quote
Old Oct 18th, 2011, 4:03 pm   #2 (permalink)
jet057's Avatar
NO,and i don't think so.
2007/ducati-ST3-S-ABS 2002-Honda 250
jet057 is offline   Reply With Quote
Old Oct 18th, 2011, 4:14 pm   #3 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
I dont have any personal knowledge of how it would fit up, I do think its doable.
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Oct 18th, 2011, 5:27 pm   #4 (permalink)
I guess I'll have to find out the diameter of the stock st2 forks and the diameter of the 696 forks. Or figure out which bike has the same dimensions of the top triple so I can find an easy swap.
Andy
Old Oct 18th, 2011, 11:57 pm   #5 (permalink)
I have one in the garage I used, I believe it was off a 620 monster, just because it was cheap. I wanted to see if it would fit, it was fine with a little grinding to the guage mount area of it. So they wouldn't contact my guages.
I didn't use bars on it, I used ST3 risers and bars, so I needed different upper clamp to clear the risers.
you could probably find some photos in my posts from mid 09 about my naked ST2, ST2+, ST2CR etc.
danrduc is offline   Reply With Quote
Old Oct 19th, 2011, 7:26 am   #6 (permalink)
SS904's Avatar
Beyond the triple clamp fitting, you would have to consider faring clearance, especially at full lock. It's a little tight even using Cycle Cat clip ons and they don't have a huge amount of rise over stock. Not sure where the bars you want to use would place the grips and fluid reservoirs compared to already available aftermarket risers and clip ons, but it's worth looking into clearance as well. You can reduce lock to lock travel using the adjusting bolts on the lower triple to gain some additional clearance, but that can make a bike already a bit hard to maneuver at parking lot speed a little worse. Post some pics if you pull it off.
Dan.
A man said to the universe:
"Sir I exist!"
A sense of obligation."
Stephen Crane
SS904 is online now   Reply With Quote
Old Oct 19th, 2011, 1:38 pm   #7 (permalink)
nice, maybe I will look for a 620 clamp, do you know the form dimensions?
Andy
Old Oct 19th, 2011, 1:39 pm   #8 (permalink)
Clearance is not of too much concern for me, if it clears that would be good, if not I have no problem taking the fairing off and making it a naked bike, I dont do too much touring and I enjoy the look of a naked bike.
Thanks for the heads up
Andy
Old Oct 20th, 2011, 11:59 pm   #9 (permalink)
I "think" most of the monsters have the same[simular]clamp, the 620 was just bargain priced, a cheap test.
The naked ST will reveal much more than you hoped for and be a lot of work.
53mm upper triple. Duc_Fan Sport Classic 12 Sep 28th, 2011 1:56 am
FS: 999/749 upper triple Porsche Barry Parts and Accessories 1 Nov 12th, 2010 10:39 pm
Triple upper sizes? Porsche Barry Multistrada 2 Oct 23rd, 2010 6:45 pm
xx9 triple upper and lower TAftonomos Parts and Accessories 0 Mar 14th, 2010 11:35 am
upper triple clamp 999 to 998 tjona Superbikes 1 Jul 27th, 2009 5:24 pm
