Oct 14th, 2011, 12:37 pm
Noticeable groaning when …
Noticeable groaning when I pull away from a dead stop unless it’s fairly gingerly. Vibration too. Feels almost like its coming from the left side.
Anyone got an idea ?
Thanks
1999 ST4
Lower Merion PA
Oct 14th, 2011, 12:45 pm
Life is too short to worry !
Thanks
When was the clutch last looked at ?
(I realise its not on the LH)
Could be a build-up of dust.
Oct 14th, 2011, 12:54 pm
Thats a good question... the clutch does not feel like its slipping.
Okay another dumb question... the window on the left side of the motor I assume it’s to line up timing marks?
1999 ST4
Lower Merion PA
Oct 14th, 2011, 1:22 pm
The window shows the TDC poisition of the vertical cylinder. There is a mark on the rotor that lines up with the pointer in the window at TDC. The marks on the belt drive pulleys and the clutch cover line up when Horizontal is TDC.
You are what you practice to be.
'98 M750
'99 ST4
'00 748R (almost RS, track only)
'08 1098 (track only)
Oct 14th, 2011, 1:49 pm
Check the clutch plates
Oct 14th, 2011, 3:01 pm
someone else described that sound as chewbacca groan. Mostly likely glazed or worn clutch. Numerous threads on pulling the plates, and if still in spec for thickness you can send them lightly to remove the glaze.
Chris
12 1199 Panigale......May 26th?????????????????????
10 Ducati Streetfighter
2011 Aprilia RSV4-R APRC
05 Goldwing
Oct 14th, 2011, 3:08 pm
Check your air pressure!!!
Check the main nut on the hub!
Here is a write up I did on cleaning the clutch.
Cleaned my clutch today!
On the left side check the chain and the primary sprocket for wear or binding.
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Oct 14th, 2011, 6:10 pm
Señor Member
Thanks
I am not here to help in any way: Did you check to see if my ex-wife was on the back with you?
Oct 14th, 2011, 6:28 pm
Still needs a life.
The clutch of my 02-ST4s sounded that way as I would start up a steep hill with the OEM 38T rear sprocket. I never heard the sound again when I switched to a 42T rear sprocket.
Oct 14th, 2011, 7:00 pm
Thanks
So, what you're saying here is: Your bikes groans when you ask it to work???? Maybe you should bring it to an Occupy *fill in the blank* protest and demand someone to fix it for you!
Clean the clutch as va duc says. Pretty much needs to be done once or twice a season depending on how you ride and how much the noise bothers you.
Dan.
A man said to the universe:
"Sir I exist!"
A sense of obligation."
Stephen Crane
