OK you motorheads..help w/ starting problem - Ducati.ms - The Ultimate Ducati Forum
Old Oct 13th, 2011, 7:18 pm   #1 (permalink)
ST4Rick's Avatar
Images: 2
Here's the scenario...Background first: '03 ST4s, 20k miles, not ridden very much this season, but kept on a battery tender always in the garage. Battery is 2-3 years old. When it hasn't been started in a few weeks, it gets a bit stubborn. That is relatively normal. I know that this bike draws a lot of juice to crank, so sometimes it won't start after cranking a bit, but after letting the charger work for a an hour or 2 it has always kicked over the next try.
Recently (like the last few days) when I turn the key to ON, I see the yellow dash security light go solid for a second, then nothing. No fuel pump buzz, no headlights, no power to starter. If I turn the key off and on a few times, it will eventually start the normal buzzing and clicking sequence and lights go on and will fire up. After I ride, if I shut down for a gas stop, I have to hope it doesn't give me a problem starting up again. Electrical gremlin? battery problem? CPU? Any insight? Thanks Rick
Doctor Rick
'03 ST4s Senna wolf in Ducs clothing
'04 Kawasaki 636 track bike #719
'02 Ninja 500 my commuter, and wife's weekender.
ST4Rick is offline   Reply With Quote
Old Oct 13th, 2011, 8:08 pm   #2 (permalink)
assuming your not touching the kill switch the only change is turning the key on and off, then I'd get the battery checked, sounds like its shorted. Normally you would hear the relays under the seat pull in followed by the fuel pump
longdrive is offline   Reply With Quote
Old Oct 13th, 2011, 11:12 pm   #3 (permalink)
Motard-Menace's Avatar
I've got a $20 spot says your battery is shot. Your symptoms sound like issues related to the battery not having/holding a full charge. My 2 cents
MOTARD-MENACE
07 BMW F800S
Old Oct 14th, 2011, 2:29 pm   #4 (permalink)
ST4Rick's Avatar
Images: 2
Even though its a 2 y/o battery, its always on a battery tender...I hope its that simple!
Doctor Rick
Old Oct 14th, 2011, 4:05 pm   #5 (permalink)
ST4Rick's Avatar
Images: 2
battery: 12.8v at rest, 11.6v cranking, 13.5v @3k rpms. No corrosion on battery terminals. Any help?
Doctor Rick
Old Oct 14th, 2011, 4:15 pm   #6 (permalink)
Images: 2
I had the same with a 748, turned out to be 40A ignition relay, symptoms were identical
Hope that helps
duncan748 is offline   Reply With Quote
Old Oct 14th, 2011, 6:20 pm   #7 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
Just in case.
For the ignition relay (2 - "87" terminals and no "87a" terminal):
GM - 20414941
Tyco - V23234-C1001-X006
Bosch - 0 332 019 155
Hella - 87453
Napa AR274 or sku 707390822143
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Oct 14th, 2011, 7:19 pm   #8 (permalink)
ST4Rick's Avatar
Images: 2
Why can't I find "ignition relay " in an OEM parts catalogue? Does Ducati refer to it as something else? Exactly where is it located on the bike?
Doctor Rick
Old Oct 14th, 2011, 8:48 pm   #9 (permalink)
va duc's Avatar
Images: 12
big yellow relay located on the left hand side of the bike up in the faring bracket. I think its # 11?
The part # is 28740141A
AMA Member
1998 Silver ST2$
Old Oct 14th, 2011, 10:06 pm   #10 (permalink)
I guess I owe you $20 bucks......let us know if the relay fixes the issue......goodluck
MOTARD-MENACE
07 BMW F800S
Starting problem still ...Need help.. thanks vt_tj Monster 8 May 21st, 2009 4:21 pm
748 starting starting problem 2000ks748 Superbikes 5 Jun 30th, 2008 7:14 pm
Starting Problem Ric Supersport 4 Nov 10th, 2007 1:47 pm
starting problem mcevok Superbikes 14 May 2nd, 2007 6:51 pm
996 starting problem Cobra Superbikes 6 Jan 26th, 2007 2:50 pm
