'Popping' your clutch - Ducati.ms - The Ultimate Ducati Forum
Old Oct 12th, 2011, 8:21 pm   #1 (permalink)
So my 'new' 2002 ST4S doesnt want to turn over in cold weather (unclear if old battery, batt not getting power, etc)
Anyway, I live atop a hill and have been starting it that way. Bad for the bike?
I don't intend to do long term but am waiting on new cables to install and if that doesn't work I'll go to battery and if that doesnt work go to rectifier.
So bad to pop?
2002 ST4S (2011-)
1977 Triumph (2000-)
2001 Triumph ST (2003-2011 RIP)
Kierantaylor is offline   Reply With Quote
Old Oct 12th, 2011, 8:51 pm   #2 (permalink)
No different than push starting a road racer - won't hurt anything. Roll downhill, put it into 2nd with the clutch in, stand up on the pegs, sit down hard as you pop the clutch - on the road!
There are plenty of threads here on what battery voltage should be at rest and at various RPM's - a good voltmeter would be useful - I'm about to mount one up, since these bike seem to hit the battery quite hard when you hit the starter button.
'98 ST2, '75 Norton Mk III
ptourin is offline   Reply With Quote
Old Oct 12th, 2011, 9:04 pm   #3 (permalink)
Extended Member
CAlexio's Avatar
I've never been able to start a ducati by popping the clutch... even with 3 friends pushing it... it just compresses to a halt each time.
Old Oct 12th, 2011, 9:54 pm   #4 (permalink)
de riguer in the Winter for my former 93 SS750. hard to do on the ST4
1965 Suzuki Hilly Billy (stolen)
1968 Kawasaki A1SS
1970 Kawasaki A7
1978 Suzuki GS400e (sold)
1980 Suzuki GSX550e (sold)
1982 Honda CB400 (sold)
1983 Yamaha XT125 and DT 125 (traded in)
1988 Yamaha DT200 (traded for leathers)
1988 Gilera Saturno 500
1993 Ducati 750SS
2004 ST4s ABS (yeller)
Mad Dog is offline   Reply With Quote
Old Oct 12th, 2011, 10:10 pm   #5 (permalink)
So bad to pop?
why don't you get the battery tested at you local Ducati dealership to see if its good?
DesmoRR_16 is offline   Reply With Quote
Old Oct 13th, 2011, 6:42 am   #6 (permalink)
Stick's Avatar
The only weird thing I can say on the ST4s, and bump starting it, is the fact that you have only about 10 or 15 seconds from when the key is switched to ON to do the deed. Otherwise, the immobilizer will kick in, and you'll get no fuel or spark.
So what I've done on a 20 degree F day (bike was "new" to me, and I missed a couple of start attempts, battery got too drained for the starter to work...):
Place in 3rd gear, "pre-jogged" the engine so that one piston was up high on its comp. stroke, had one gent help me push it on flat driveway at work. Last thing I did was turn the key on, just before popping the clutch -- I was amazed that it started...
Stick
Other brands (past):
Old Oct 13th, 2011, 4:48 pm   #7 (permalink)
Leary Blaine's Avatar
Try 2nd gear
Are you popping in second gear? That happens to me if I forget and try 1st gear. Although I must admit that I've always used a hill ... never people pushing me.
Leary Blaine is offline   Reply With Quote
Old Oct 13th, 2011, 8:30 pm   #8 (permalink)
Hmmm. I have been doing it in first gear- didn't know about second.
Re the ignition, yes I found through trial and error that it works better when you turn key and push starter just before you pop the clutch. Won't spark otherwise as the earlier post said
This worked for me in first gear last night on a very slight hill.
Guess I will try second gear tomorrow!
Yes, I did get an appt with my local dealer. I'm at 12k now and not up to doing my own valves and belts so I figure get it done right for the first time.... Going to put the powerlet leads to the battery too and probably the ram mount center nut thingy.
2002 ST4S (2011-)
Old Oct 13th, 2011, 11:08 pm   #9 (permalink)
Motard-Menace's Avatar
Agreed, much easier in 2nd.....I have pushed mine by my self and popped her to a start in 2nd.
MOTARD-MENACE
07 BMW F800S
Excessive popping on my new EVO liwanacf Superbikes 8 Oct 14th, 2010 12:07 pm
Anyone having trouble wheeling by popping the clutch on the Hyper EVO krisnet55 HyperMotard 47 Sep 1st, 2010 10:48 am
999 popping??? lopedogg Superbikes 4 Mar 11th, 2010 7:51 am
the popping is gone[almost] roadron Supersport 4 Apr 11th, 2007 10:56 am
