907 Paso Speedo cable? - Ducati.ms - The Ultimate Ducati Forum
Old Oct 11th, 2011, 2:40 am   #1 (permalink)
GreyDuck's Avatar
G'Day,
MY mates 907 Paso does not have a working Speedo or tacho.
Woud this be a broken cable?
If so where can he buy a replacement?
Any suggestions?
Thanks for any help.
ps he's 70 yrs of age & still riding strong
GreyDuck is online now   Reply With Quote
Old Oct 12th, 2011, 2:40 pm   #2 (permalink)
ducsrfun's Avatar
The speedo runs via cable (from front wheel) however the tach is electronic.
My outer cable housing was good so I just replaced the inner cable with a universal aftermarket replacement from an auto store... by cutting it to length....
Randy
'04 ST4s
'00 Cagiva Gran Canyon
'91 907ie
'91 907ie (wrecked/parts)
'98 KTM 380 EXC
'57 Triumph Tiger 110
ducsrfun is offline   Reply With Quote
Old Oct 12th, 2011, 5:32 pm   #3 (permalink)
GreyDuck's Avatar
Thanks Randy,
I'll pass on the advice.
Seems as though Paso owners are a bit thin on the ground around here.
Old Oct 18th, 2011, 12:58 pm   #4 (permalink)
Oh, there are still a few of us around here ..... don't give up. 907's were the best of the Paso line up and well worth the effort.
Try ducatipaso.org for more detailled info on the Paso line.
Many parts were/are shared across the older SS model and are still readily available. If anything, ask for an older guy with some experience at the parts counter. There have been part number changes over the years, someone may have to spend some time looking up the superceded numbers.
'05 ST3
'90 906 Paso
It's not just a Ducati, it's a disease!
jack is offline   Reply With Quote
Old Oct 18th, 2011, 6:53 pm   #5 (permalink)
Images: 69
>>My outer cable housing was good so I just replaced the inner cable with a universal aftermarket replacement from an auto store... by cutting it to length....<<
+1, works fine.
>>The speedo runs via cable (from front wheel) however the tach is electronic.<<
No, mechanical, tach has same type of cable as speedo.
http://ducatipaso.org/ is recommended, lotsa knowledge there.
greenmonster is offline   Reply With Quote
speedo cable scoobysnax22 Superbikes 12 May 9th, 2011 9:41 pm
916/748/996/998 Speedo Cable 94CobraR Parts and Accessories 0 Apr 7th, 2010 9:00 am
748 Speedo Cable gchiasson Superbikes 2 Mar 19th, 2009 9:30 pm
748 Speedo cable NSXDude Superbikes 0 Sep 29th, 2008 12:42 am
Help! will a speedo cable fm ST4 fit on 996? redzedx7r Superbikes 2 Mar 26th, 2008 11:46 am
