Oct 4th, 2011, 8:09 am
Moderator
Rear Brake
I've always maintained when peeps complain about their rear brake that if you use it regularly, it will work well enough. Last night, while out for a ride and during the time I rode in stop and go traffic in town, I used it exclusively which I often do. It worked so well I felt compelled to remark about it today. No issues with stopping power or modulation. That being said, yes, it's not the most powerful, but otoh, I used a bit of force on the pedal at times and it never locked up/slid the rear.  I still have the OME pads on the rear, and bleed the system yearly.
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
Oct 4th, 2011, 8:29 am
Life is too short to worry !
It can be pretty pathetic as it arrives from the factory but a little careful adjustment and regular maintenance helps immensely.
Mine was useless initially but after a little work now operates fine and sufficient fotr its purpose.
Oct 4th, 2011, 10:41 am
You guys are jaded - you should ride a Norton and then get on your ST - the stock front disc on a late Commando feels like you're pushing a block of wood against the rotor <g>...
'98 ST2, '75 Norton Mk III
Oct 4th, 2011, 10:52 am
The rears on all three of my bikes work about the same, PERFECTLY !
They give me exactly what I want and need when I ask for it. I couldn't imagine them being any better.
None of them can lock the rear tire when used by themselves. 45mph, pull in the clutch and mash as hard as I can. No lockup. I can get more braking power by downshifting than using them.
For fine control while riding I wouldn't want it any other way.
Mike
Oct 4th, 2011, 1:13 pm
Agreed.
I love my ST rear brakes.
Oct 4th, 2011, 1:58 pm
only brake to use on low speed turns or gravel, and for rolling up to a give way junction and virtually stopping without putting a foot down.
Tim
ST2 1998 custom
Oct 4th, 2011, 2:00 pm
Wet autumnal leaves also spring to mind Tim, as does early unexpected frost.
Oct 4th, 2011, 4:49 pm
Completely agree with this thread. Had to make adjustments to the pull of the lever but once I did that it works great and I use it all the time.
2006 ST3
Oct 4th, 2011, 4:50 pm
Just for grins, on the way home I did an experiment (played around).
There's a road that goes by a big pipe lay down yard. It's smooth polished asphalt and always covered with a very visible layer of white dust. More slippery than rain on good pavement.
50 mph, pull the clutch in and nail the rear brake. Pressing way harder than I would normally, I was just able to engage the ABS. In fact, first time I've ever done that on the rear. I was impressed how well ot worked and could just feel the pulsing through the pedal.
Mike
Oct 4th, 2011, 6:50 pm
Dare I ask . . . .what's the favourite brake pad?
I need to change mine. I'm at 30,000 miles and assume that I'm not using the original pads (I've done 7,000 miles since I bought it)
thanks
David
Ducati rider since '74
1966 250 Mark3
2004 ST3
