ST4S : radial brakes - Ducati.ms - The Ultimate Ducati Forum
Old Oct 2nd, 2011, 1:40 pm   #1 (permalink)
i'll be here till my 85!
kope999R's Avatar
Images: 7
I did my fist 200 mile stint on the ST4s ABS i got last week.
coming from a kitted 999R i had to adjust but love the bike.
the only thing leaving me wanting is the brakes. being used to some upgrade Brembo Perfomance calipers and master cylinder, the standard brakes a a bit of a let down...
can anyone give me the size of the showa forks that fit the yokes?
has anyone any experience with upgradeing the brakes?
tx
Koen
999R (05 # 204) - rise and shine - little project
ST4S abs (2003 ) - lets go walkies
MS 1200 Sport (2011) - rolling rolling rolling
916 SP - 94 - sold
851 Strada - 92 - sold
husky 510 - 90 sold
husky 610 - 91 sold
kope999R is offline   Reply With Quote
Old Oct 2nd, 2011, 3:18 pm   #2 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
The BREMBO 7850 Series "4 Pad" Cast Caliper: 65mm Axial are a direct bolt on to the forks. You may need a side mount brake line.
The ST4S uses 50mm forks with a 65mm mount.
I'm adding the BREMBO "RCS" Forged Radial Brake Master Cylinder as well as the calipers this winter to my ST4S.
I upgraded the rotor with CORSE DYNAMICS Full Floating Rotor Button Kit: 20 and cleaned them thorughly with a Rotor Hone Tool to remove any old brake pad material.
-M
moto is online now   Reply With Quote
Old Oct 3rd, 2011, 3:23 am   #3 (permalink)
Life is too short to worry !
Gearbox's Avatar
"The BREMBO 7850 Series "4 Pad" Cast Caliper: 65mm Axial are a direct bolt on to the forks. You may need a side mount brake line."
These look the same as the standard (Teflon coated 4 pot pistons) fitment so what is the difference/improvement ?
(Just asking)
Gearbox is offline   Reply With Quote
Old Oct 3rd, 2011, 6:54 am   #4 (permalink)
Puffin64's Avatar
I have a set off 916/996 showa forks Ti coated to fit on my ST2, but found they are a different size, so I have purchased the bottom yoke off the 916/996 and plan to use the top yoke off the ST2. It had to be bored out as the tops of the 916/996 forks are 53mm, but it can handle 1.5mm off each side as the others are 51mm.
Mine are supposed to have Ohlin internals according to the guy off ebay I got them from, I will found out when I get the fork seals changed if he's been telling porkies or not.
I've also converted mine to the P4 calipers found on the 999, and find the braking great when I use them; but with a V twin that isn't very often with all that engine braking.
I'm also using the 916/996 master cylinders in place of the coffin style ones I had before.
Tim
ST2 1998 custom
Puffin64 is offline   Reply With Quote
Old Oct 3rd, 2011, 11:34 am   #5 (permalink)
guido's Avatar
Hello, Gearbox
The four seperate small pads allow for better pad contact than two large pads.
Almost always, when you pull your pads after mega miles, you see where the leading or trailing edge (usually leading) is worn substantially more than the remainder of the pad.
Using more and smaller pads helps to eliminate that and promote even pad load distribution.
Or that's what little I know about it anyway....
guido in Houston
'03 sT4s ABS (sport TOUR)
'02 St4s (SPORT tour) w/ MBP Testarosso heads, DucShop Crank w/ Carrillo Rods, Pistal Pistons
'05 S4R - Work in Progress
'07 S4RS - Work in Progress
'03 ST4S-RS Moving past conceptualization......
'80 BMW R1050S Hybrid Cafe (gotta get back together soon...)
"It ain't really "yours" until you've MODIFIED it!"
guido is offline   Reply With Quote
Old Oct 3rd, 2011, 11:49 am   #6 (permalink)
guido's Avatar
Hello
I have a stock braking system on my '03 sT4S except for **9 radial masters, aftermarket hoses from master to ABS unit, and TPO floating buttons in the rotors. It stops pretty adequately, two-fingered stoppies all day long (don't let anybody tell you ABS defeats stoppies)
My '02 St4S (non-ABS) has 1098 radial masters, dual hoses to four-pad **9 calipers w/HH pads, and BrakeTech Axis iron rotors.
Those friggen' brakes scare me.
I can't tell you how many times I've inadvertantly "chirped" the front tire (Michelin Pilot Pure's) with one finger on the lever.
I can't imagine why anybody on God's green earth would need or want more powerful brakes than those.
I'm scouting for some pads compatible with the iron rotors that maybe provide a bit less initial bite than the EBC's I currently have, but other than that, if you're looking for brakes for your ST4S, this setup will do the trick.
Not really ABS compatible, though. I'd go with radial master (1*98) and four pad calipers shouldn't mess up the ABS stuff. You may need new lines from the masters to the calipers, though. Different angles on the banjos.
JMHO....
guido in Houston
Old Oct 3rd, 2011, 12:12 pm   #7 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
Originally Posted by guido View Post
two-My '02 St4S (non-ABS) has 1098 radial masters, dual hoses to four-pad **9 calipers w/HH pads, and BrakeTech Axis iron rotors.
Try the
FERODO 'ST' Sintered Brake Pads:4 pad
These were designed to be used with ductile iron rotors such as the and have less initial bite than the EBC HH.
I 've used these pads on several bikes that have the Brembo 4 pad calipers. They are much less abrupt and have better control than the EBC.
-M
Old Oct 3rd, 2011, 1:28 pm   #8 (permalink)
kope999R's Avatar
Images: 7
tx guys!
wonter is approaching fast and it ill be interesting to ponder all the options.
ain't it fun!
regards
Koen
916 SP - 94 - sold
husky 510 - 90 sold
husky 610 - 91 sold
Old Oct 3rd, 2011, 1:47 pm   #9 (permalink)
MarkST's Avatar
I hate wonter, it is very tedious.
The wonters over here in the UK are horribly gray and seem to last forever.
MarkST is online now   Reply With Quote
Old Oct 3rd, 2011, 2:26 pm   #10 (permalink)
SS904's Avatar
Depends on what you feel needs improvement. I can't compare braking power to your 999, but here's the progression of upgrades I've done. They have mostly been to counter the brake judder that appears to be inherent with the OEM pads and Brembo "snowflakes" that come on the S models (often misdiagnosed as a warped rotor).
Full floating rotor buttons with OEM pads and OEM rotors. Judder completely gone, very low to none at all brake drag. Had that set up for a long while. Worked well for me, but eventually became tired of the sloppiness and rattle.
Most recent change was to Ferodo Platinum pads and a set of significantly lighter OEM rotors off a base 998. Perfect so far. No judder at all. Minimal brake drag, as the organic Ferodos have a fairly low initial bite. Improved feel with more (progressive) power than the OEM set up. I have also tried EBC HH sintered pads with the OEM rotors. Just too much initial bite for me. If you’re looking for outright stopping power, I’d say give those a try.
Never really felt the OEM set up lacking in power, but I only ride on the street and I'm one who uses 4 fingers to stop when I need to stop, two to control speed, and stoppies scare the sh*t out of me, so I don’t even try...
Dan.
A man said to the universe:
"Sir I exist!"
A sense of obligation."
Stephen Crane
SS904 is online now   Reply With Quote
Brembo Radial 19x20 siezing up brakes crashtest22 Supersport 10 Aug 4th, 2011 3:22 am
what xx9 came with radial brakes? triple9 Superbikes 7 Feb 25th, 2009 2:35 pm
Standard-added the radial Brakes? sinex HyperMotard 6 Dec 17th, 2008 2:40 am
Radial brakes 916, project finished..... DukeDesmo Superbikes 14 May 10th, 2008 12:41 pm
996 conversion to radial brakes question charliep Superbikes 1 Mar 7th, 2008 7:26 pm
