Oct 13th, 2006, 1:58 am
Exhaust Modifications....stock!
i've ran across plenty of pages detailing how to modify the mufflers on monsters and other Ducatis but when i pulled my pipe apart on my ST it was different so i jsut put it back together. then had an idea on how to get the exhaust to exit the 2nd chamber without having to cut the entire exhaust apart to remove the tube from chamber 2-3.....did it all without ever taking the exhaust off the bike. maybe there is someone that has done this, or had the idea but I never ran across it in my searches. so here it is.
on the back of the pipe between the center actuall exhaust exit and the outside endcap circle I used a punch to mark my spot then drilled the holes. I think it took me about 20 minutes to do both pipes. I started with 4 holes in each and still wanted it louder so drilled more testing the sound along the way. i'm no ducati fuel injection expert either but i decided to up the fuel trim a little inside the computer to compensate for any leaning plus I read they are lean from the factory anyway. might jsut be me but it did get rid of a slight poping I had on decel. I have noticed no weird flat spots or anything with how the bike runs after doing this and have abotu 500 miles on it. man it sounds great and no one even notices....if they do it almost looks like the exhaust was made this way.
ok now here are the pictures. ON MY WEBSHOTS PAGE!!
thoughts, opinions, flames?
Donny O.
98 Ducati ST2...SOLD 10-15-08
98 Kawasaki Concours
87 Suzuki Cavalcade w/California Friendship III sidecar
Oct 13th, 2006, 7:50 am
Nice work! I still want some carbon pipes for mine though. For the look AND the sound. Friends still say the ST4s sounds really good with the stockers riding behind me but that still doesn't suffice. May try your method 'til then.
'08 ZX14 and '02 ZRX1200R
...previous Ducatis now sold... '05 999 and '02 ST4S
Oct 13th, 2006, 12:11 pm
I could go take some video of it and see if that does the sound justice if anyone cared!!
Donny O.
Oct 13th, 2006, 10:53 pm
I would listen DonnyO, I have stock cans on 04 ST3. As much as I'd like more sound by doing it on the cheap like you did, I'd still be leary of messing up a good thing; it's run great for 38k now.
I'll leave it up to you if you care to take the time to do so.
Thanks for the offer. jim
Oct 14th, 2006, 12:24 am
I will take some vids when i get time. I figured if it was that bad stock cans can be found on ebay fairly cheap.....lots cheaper than anything aftermarket....and i'm cheap and broke!! I did hear another guys who did soemthign similar so I had an idea of what it would sound like. with only 4 holes in each it sounded like an exhaust leak so I had to put more in. I could make the holes bigger if needed as well but i'm happy for now. didnt' wnat to wake the whole town with it but wanted some sound.
Donny O.
Oct 15th, 2006, 12:55 pm
I am looking forward to your vids...I have the exhaust apart twice at a local shop and was told that there is nothing I can do....I got a set on ebay for $50 and would like to try your way
Oct 16th, 2006, 3:42 am
well then maybe between rain drops tomorrow I will go get the vids. I took some vids for people that wanted to hear the exhaust on my cavalcade(harley road king mufflers)...to make the file size smaller the picture ends up looking like crap....jsut a sony handycam....but the sound is the same!!
Donny O.
Oct 16th, 2006, 4:19 am
What I would like to know is what it sounded like with the baby mice in the air box??? Dang!
S Starbuck
2005 Ural Patrol "Nell"
2005 1000DS SS "Bell" (Sargent saddle and tank bag, Fender eliminator, SCP billet clutch cover [black and open], Red SM Kukri Pro clutch plate, SS springs, Gold keepers, Ti Termi high mount ovals, Shift-Tech CF belt and sprocket covers and front fender, Carbon-Teile CF heel guards, Lockhart Philips turn indicators, Ducati-Kamna seat cover... no mo' rear plastic hugger or air box snorkels neither)
2007 Yamaha YZF-R6 "Yell"
Oct 16th, 2006, 12:59 pm
At another forum I read a story about drilling out the rivets at the back plate of the muffler, take the inner assembly of pipes out and cut 2/3rds off before remounting the plate again and riveting it back in place.
Haven't tried it myself though so not sure whether this is true.
i modded my pipes. It was easy. just take the rivets out and remove the caps then cut from the inside smallest tube to where the larger ring on the cap is, you can turn the cap around and trace it with a sharpie, just cut the donut piece out. you can drill holes all around the tracing then cut between the holes to make it easier. I had to cut my airbox open and get a dp chip to get it to run best. Heres what i did, dont mind the earlier pages just start here.
http://home.earthlink.net/~desmoduck..._modpics5.html
dont cut the center pipe at all just that ring in the pics. When i finished i threw a bit of black engine paint in there to hide the cuts. BTW, it sounds great and not too too loud.
1998 ST2 streetfighter, SSSA from s4r convert, 998r wheels, relocated electronics & battery, handlebars, dual headlights, no bodywork, boom tubes exhaust made custom for my application. GP shifter, lots of other mods.
