May 26th, 2011, 11:31 am
Chilehead
Broken speedo drive (ST2), fixable?
Started my ST2 today for the first time this year, started right up, BUT the speedo doesn't work (it worked when I put it away).
So, turns out the speed drive is blocked.
Anyone ever fix one/take it apart?
Thanks,
Tom
1985 LeMans
1986 LeMans w/ sidecar
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
May 26th, 2011, 11:35 am
Not on a Ducati, but I have worked on other cable speedo systems, and yes, some can come apart and can be serviced somewhat. When's the last time it was lubed?
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
May 26th, 2011, 11:59 am
Chilehead
Don't recall, but it's full of grease.
Anyway, found one on EBAY for $30 from a guy I've bought other stuff from, so I should be set.
Just wondering how to take it apart, guess I'll start with the roll-pin.
Thanks,
Tom
1985 LeMans
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
May 26th, 2011, 12:59 pm
Mr Leakered
Yes, you have to extract the roll pin.
Mine went out last year. I saw some used ones and just didn't want to risk another failure with a used part. 500mi with a bicycle speedo once was enough.
The drive gear on the new one appeared to be plastic/nylon and not packed well with grease. I added quite a bit of moly. I've heard these are a common failure item and can see why.
BTW, mine finally broke when rolling the ST backwards. If you were putting yours away, that might have done it.
Have a good one.
tony b
2001 ST4 (Huile and Vinegar)
May 26th, 2011, 3:33 pm
Chilehead
Mine when out last year. I saw some used ones and just didn't want to risk another failure with a used part. 500mi with a bicycle speedo once was enough.
The drive gear on the new one appeared to be plastic/nylon and not packed well with grease. I added quite a bit of moly. I've heard these are a common failure item and can see way.
Have a good one.
Thanks.
Once the roll pin is removed, do you just pull the guts out or what?
Tom
1985 LeMans
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
May 26th, 2011, 4:12 pm
Mr Leakered
I saw a diagram somewhere for it when I was considering what to do with mine. But, I believe the threaded brass output shaft just pulls out.
Have a good one.
tony b
May 27th, 2011, 7:58 am
Chilehead
Got it apart, the output shaft was frozen which wercked the plastic drive gear. So I'll just re-install it without the gear while waiting for the one I bought to arrive.
Tom
1985 LeMans
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
May 27th, 2011, 9:14 am
Mr Leakered
Bummer. That is what I did, just removed the cable and ran that way for a few weeks. The crazy part was that 64mph+ was the high limit of the bicycle speedo. It would stop recording mileage also, so I was guessing and filling up early. Plus the small update lag made for pure enjoyment once the speedo was fixed.
Have a good one.
tony b
