Mar 17th, 2011, 7:50 pm
Would you drill a hole in the plastic panels beside the seat?
I might get struck by lightning just for asking, but I was thinking of putting those hook thingies on the plastic panels (what are those called) on either side of the seat. I would be able to hook a bag bungie to them instead of hooking the bag bungies to each other under the seat.
The hole would be the size of a regular bolt, and would be completely covered by these ghastly but highly utilitarian devices. They're about 3/4" in diameter and half an inch high. Nicely rounded, they'd look just fine on a Beemer, but I'm afraid to put them on a Ducati ... might disturb the Earth's magnetic field. Or worse.
Would you?
I could paint them red, I suppose ...
ape
Ducatis Owned
01 Yellow 748
08 Red Multistrada 1100S (sold)
03 Red ST4s w 996 4-valve and Ohlins (sold)
01 Red ST4 w 916 4-valve (sold)
05 Red 800 Supersport (sold)
Mar 17th, 2011, 8:06 pm
I think I'd buy some off eBay and drill the holes in those... The other thing is I’d think pretty hard about how much weight I planned to strap to those hooks. You may want to take a good look at how these panels are attached! Not particularly confidence inspiring given you plan.
Another option it to rig something under the seat similar to what Sargent and the DP seats use. The both have swing-out hooks riveted to the seat pan.
Dan.
1995 916 (build in progress...) http://lacks-focus.smugmug.com/Trans...6167&k=DqLhZ94
A man said to the universe:
"Sir I exist!"
A sense of obligation."
Stephen Crane
Mar 17th, 2011, 8:07 pm
I wouldn't do it but not because I'm worried about looks but because I've found those plastic panels to be fragile (I've cracked the mounts on one.)
Mar 17th, 2011, 8:19 pm
Yeh - just take a look at the fasteners that hold the pieces to the frame. Trusting them to hold anything at all would be a serious risk. JMHO, tho.
dave crawford
2003 ST4s - yellow!
Raleigh, NC
Mar 18th, 2011, 9:37 am
Mr Leakered
Also, there are some that have installed bunge hooks on the panniers. That is a much better place than the seat fairings. The seat pan idea is great also.
Have a good one.
tony b
2001 ST4 (Huile and Vinegar)
Mar 18th, 2011, 10:10 am
Hooks
Or, if you had a Sargent or DP seat, you could just swing out the hooks from underneath the seat and use them....
06 Ducati ST3s
86 Suzuki RG500 Gamma
84 Honda VF1100S (Gone but not forgotten)
73 Yamaha RD350
Mar 18th, 2011, 10:24 am
I did this to mine and it works pretty well.
ST Bungee Net Attachment Mod
I wouldn't expect it to hold a hundred pounds, but it works well for an extra helmet or if I have to pick something up at the store.
2003 ST4s ABS
Mar 18th, 2011, 10:31 am
Great idea - I think it's as strong as the Sargent set up. too.
dave crawford
2003 ST4s - yellow!
Raleigh, NC
Mar 18th, 2011, 3:25 pm
I've been thinking of using mounted cable ties attached to the frame.
They are essentially zip ties with an eyelet in them to put a screw through.
They have a million and one uses, I originally bought them to mount wiring to firewalls on Jeeps, but I've found a ton of uses since then. I think they'd be ideal for the purpose and you can buy them at Home Depot/Lowes.
I'd zip tie them to the frame, and use the eyelets to attach the bungee net.
'06 xb11.7sr
'01 ST2
'77 RD400
Mar 18th, 2011, 4:47 pm
It's gonna be a good year tater!
I did this mod myself and it will hold a seat bag nicely as well ass twerth's original usage...
Great idea twerth! Thanks for reminding me about this mod!
AMA Member
1998 Silver ST2$
