brake/clutch fluid - Ducati.ms - The Ultimate Ducati Forum
Old Mar 6th, 2011, 10:12 am   #1 (permalink)
hogan11's Avatar
brake/clutch fluid
Hello
I'm flushing the system and was wondering if any name brand brake fluid (dot 4) is better than the next?
hogan11 is offline   Reply With Quote
Old Mar 6th, 2011, 11:05 am   #2 (permalink)
It's gonna be a good year tater!
va duc's Avatar
Images: 12
Motul 5.1
AMA Member
1998 Silver ST2$
Old Mar 6th, 2011, 12:08 pm   #3 (permalink)
Shazaam's Avatar
DOT 4 vs. DOT 5.1 Brake Fluid
The DOT specification for DOT 5.1 brake fluid has a higher minimum dry boiling point/minimum wet boiling point (527°F/347°F) than the DOT 4 spec (446°F/311°F,) but these are just minimum specs. Some DOT 4 fluids exceed DOT 5.1 specs.
DOT 3 and DOT 4 fluids are compatible with DOT 5.1 but are not compatible with silicone-based DOT 5. DOT 5 brake fluid is dyed purple to warn against accidental mixing. All Brembo braking products used by Ducati have natural-rubber base seals that are incompatible with DOT 5 silicone-based brake fluids.
The use of the 5.1 designation is quite confusing.
DOT 5.1 is a lighter viscosity glycol-based fluid that was developed for use in ABS systems that need to cycle on and off quickly. It really has no advantage over the DOT 4 fluid recommended by Ducati. DOT 5.1 fluid can have worse performance after absorbing moisture than some of the better DOT 4 fluids.
For example, (expensive) Castrol SRF (590°F/518°F) is used by Formula One teams, ATE Type 200 and Super Blue Racing (536°F/392°F), and Motul RBF 600 (593°F/421°F). Golden Spectro Supreme DOT 4 (520°F/367°F) comes close.
Compare these numbers to Motul 5.1 (518°F/365°F)
Most of us don't change our brake fluid very often so wet boiling point numbers are more important. On the track, brake fade is the main concern so we change the fluid more often and use a higher dry boiling point fluid. Generally, the higher the dry boiling point, the faster the fluid absorbs moisture from the air, Castrol SRF and the ATE fluids are exceptions.
The clutch hydraulics don't see high temperatures like the brake system does so there's no need to use expensive formulations here. Any DOT 4 fluid will suffice, but remember to change it every 12 to 18 months to remove water accumulation in the fluid.
Shazaam is offline   Reply With Quote
Old Mar 6th, 2011, 12:52 pm   #4 (permalink)
SP3
SP3's Avatar
Images: 6
Go to AutoZone or your other favorite store and buy some Valvoline, Castrol, STP, whatever, name brand DOT4 and you'll be fine. Flush 'til nice and clean and ride. Repeat at your preferred interval.
1991 851 SP3
1966 250 Monza
1999 Moster 900 City (not so much City anymore)
appearing to appear to know what I know.
SP3 is offline   Reply With Quote
Brake Fluid and Clutch Slave Cylinder Fluid Changed.. strider3 Sport Touring 1 Nov 15th, 2010 10:27 pm
Brake Fluid for Clutch Buelcati Supersport 5 Oct 24th, 2008 9:50 pm
Brake/Clutch Fluid??? AXE HyperMotard 12 Apr 25th, 2008 11:56 pm
Replacement Brake / Clutch fluid Sport1000 Sport Classic 6 Jun 19th, 2007 4:00 pm
Brake/clutch fluid, where do I put it. Mati-O Superbikes 1 May 14th, 2007 12:13 pm
