Winter Maintenance - Page 2 - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jan 31st, 2011, 2:23 pm   #11 (permalink)
It's gonna be a good year tater!
va duc's Avatar
Images: 12
Originally Posted by Ronin120 View Post
I'm starting to think that compared to most here that I am so far behind on my winter maintenance tasks that I won't be done until July.
Boxing up my forks right now for shipment down to Cogent Dynamics this afternoon.
Best
Now that I am finished with mine I should be able to come give you a hand
AMA Member
1998 Silver ST2$
va duc is online now   Reply With Quote
Old Jan 31st, 2011, 2:44 pm   #12 (permalink)
I also had loose sidestand bolts on my bike too. Something to keep an eye on I guess.
RDuc3 is offline   Reply With Quote
Old Jan 31st, 2011, 3:26 pm   #13 (permalink)
va duc,
Much appreciated. When I get started in on the valves I may give you a shout. And considering my workspace, "winter maintenance" is certainly apropos given the temperatures inside the shed.
Forks shipped and getting ready to order some Nichols bolts.
Cheers
2001 KTM 400 EXC - Punkin
2000 ST2 - Blue
1999 Speed Triple - Black, the faster color
1975 MKIII Norton Commando
Ronin120 is offline   Reply With Quote
Old Jan 31st, 2011, 3:42 pm   #14 (permalink)
va duc's Avatar
Images: 12
va duc,
Cheers
No heat? Lets move it to my place
AMA Member
1998 Silver ST2$
Old Jan 31st, 2011, 4:39 pm   #15 (permalink)
craigk's Avatar
I'm embarrassed to say I let my belts go 13 years instead of 2 years. The good news is the belts still looked great when I removed the covers last night. The scary part was the tension way off. So loose they could have easily slipped a tooth. Disaster avoided! From now on I will check tension every year and change belts every two!
I guess the heat cycles and stresses caused the belts to stretch.
craigk is offline   Reply With Quote
Old Jan 31st, 2011, 6:05 pm   #16 (permalink)
MarkST asked how far out adjustment the belts were. The vertical cylinder was loose enough to do a little flapping, but not enough to contact the covers. The horizontal cylinder was fine. The engine was running fine with that adjustment. I'm sure there was nothing wrong with the belts. I suspect I simply left the horizontal one a tad loose when I installed it last year.
I don't use anything special to adjust them. I just put them on and tighten them where I think they ought to be. Tight enough to not flap. Not too tight as to stretch them. Quality of the CA Cycleworks belts is excellent - better than OEM, probably. Next year I'll put another set on.
2005 ST3 Black
860GT is offline   Reply With Quote
Old Feb 1st, 2011, 12:38 am   #17 (permalink)
craigk's Avatar
Late night wrench turning finally ended with new belts installed.
Old Feb 1st, 2011, 1:17 am   #18 (permalink)
It takes longer to uncover the belts than it does to change them.
2005 ST3 Black
Old Feb 1st, 2011, 12:16 pm   #19 (permalink)
I am in process with my ST3 24k maintenance. Belts are done, brake and clutch fluids are fresh, new oil and filter plus a new fuel filter and o-ring. I checked teh valves and need to replace the horiz exhaust closer, otherwise everything looks pretty tight. Once its all said and done I wil need a new rear Pilot Road 2CT and I'm good to go.
Alas the weather down here has been beautiful, but the bike is in parts so no riding for me.
95 Ducati 900SS/CR Red (SOLD!)
04 Ducati ST3 Silver (On The Auction Block, Buy It --> Here
76 Kawasaki KE100 Rust Brown
71 Kawasaki H1 (SOLD!)
71 Honda CL175 Maroon
74 Yamaha RS100 Yamaha Racing Green (SOLD!)
93 H-D Sportster 883 (R.I.P)
Tylerman is offline   Reply With Quote
Winter maintenance: valve shim measuring questions babyman1737 Supersport 1 Nov 18th, 2009 1:38 am
Winter Maintenance Willum Sport Touring 11 Jan 28th, 2009 4:17 am
Maintenance help 88sporty Sport Touring 11 Oct 10th, 2008 10:03 pm
696 maintenance calibretto Monster 4 Jul 14th, 2008 6:04 pm
maintenance mrTrout Ducati Motorcycle Chat 4 Jul 20th, 2006 8:55 am
